Wed, Dec 25, 7:34 PM CST
Renderosity Forums / Poser 12
Welcome to the Poser 12 Forum
Poser 12 F.A.Q (Last Updated: 2024 Dec 22 9:02 pm)
Subject: Please Help - Lost document window in the Pose Room
thartwick1 ( ) posted Mon, 03 April 2023 at 10:18 AM · edited Wed, 25 December 2024 at 7:33 PM
I've obviously done something stupid, but I can't figure out what it is. The document window shows in the other rooms, but not in the poser room. Does anyone have any ideas?
Thanks much,  Tom
RedPhantom ( ) posted Mon, 03 April 2023 at 10:37 AM · edited Mon, 03 April 2023 at 10:38 AM
Site Admin
It sounds like the window was floating and got moved off the screen. If you have a UI dot set, you can try hitting that and seeing if brings it back. Otherwise, go into your general preferences and on the interface tab, select launch to factory state. Make sure you are on interface. There is the same option in the document tab but it does something different. Then restart poser.
thartwick1 ( ) posted Mon, 03 April 2023 at 12:44 PM
Setting to factory state on the interface fixed it. I forgot that launching to preferred and factory states is on two tabs. I had it set to factory state on the document page, but that obviously didn't fix that issue. Thanks very much. I was pulling what little hair I have let out.
Tom
RedPhantom ( ) posted Mon, 03 April 2023 at 1:30 PM
Site Admin
Glad it was a simple fix. Once you have everything back where you want, I recommend setting one of the UI dots to make it easier to fix if it happens again.
hborre ( ) posted Mon, 03 April 2023 at 2:39 PM
Simply uncheck the Drag-Docking Enabled  feature and it will remain docked until you decide to rearrange your workspace.
thartwick1 ( ) posted Tue, 04 April 2023 at 7:51 AM
RedPhantom posted at 1:30 PM Mon, 3 April 2023 - #4460635
Thanks for the tip.
thartwick1 ( ) posted Tue, 04 April 2023 at 7:52 AM · edited Tue, 04 April 2023 at 7:52 AM
hborre posted at 2:39 PM Mon, 3 April 2023 - #4460641
Simply uncheck the Drag-Docking Enabled  feature and it will remain docked until you decide to rearrange your workspace.G
Good idea. Thx.
