Thu, Feb 13, 11:38 AM CST
Renderosity Forums / Poser 13
Welcome to the Poser 13 Forum
(Last Updated: 2025 Feb 12 10:34 pm)
Subject: Show your Poser 13 renders!
DCArt ( ) posted Fri, 07 April 2023 at 7:37 AM
Larger version in my gallery
RedPhantom ( ) posted Fri, 07 April 2023 at 8:22 AM
Site Admin
ghostship2 posted at 11:03 PM Thu, 6 April 2023 - #4461080
@RedPhantom Looks good! Did you use a giant cube with a scatter volume node on it?
I was, and the camera was outside it. I only wanted it in the distance. I had plugged the scatter node into the surface rather than the volume.
Y-Phil ( ) posted Fri, 07 April 2023 at 8:37 AM · edited Fri, 07 April 2023 at 8:39 AM
RedPhantom posted at 10:32 PM Thu, 6 April 2023 - #4461078
My first Poser 13 render. I had wanted to add some fog, but it wasn't working. I'm going to have to experiment and see if I messed it up or if Poser 13 is having an issue.
Edit to add it was user error.
Really cool picture.
And if you need a setup: BB showed us all a setup, at the  time of RDNA, that still works, but it's connected to a PoserSurface Node:
I know: a sunny day with fog is weird... sYu5cq9W1NALff1DTd7HvGuOjWksU8RNKrfgmTU1.gif
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
ghostship2 ( ) posted Fri, 07 April 2023 at 9:27 AM · edited Fri, 07 April 2023 at 9:27 AM
still tweaking the shader
RAMWorks ( ) posted Fri, 07 April 2023 at 9:43 AM
hborre posted at 1:50 PM Sat, 1 April 2023 - #4460370
You need to install the Core Content first into your Library.  On startup, the selections will show up on the splash screen.
And keep in mind that if you install via Poser directly you will find your new stuff under the Runtime "Included"  Not sure why they opted for that but that's where all that is.  These environments will be located under "Scene" not under "Lights"
---Wolff On The Prowl---
My Store is HERE
My Freebies are HERE
DCArt ( ) posted Fri, 07 April 2023 at 10:14 AM
I normally don't like to post something twice but I softened her face some and like it better now 8-)
DCArt ( ) posted Fri, 07 April 2023 at 10:26 AM
And argh yes I just noticed that her right arm is poking into her stomach. I'll fix that in the gallery image.
RAMWorks ( ) posted Fri, 07 April 2023 at 10:31 AM · edited Fri, 07 April 2023 at 10:36 AM
I'm not the worlds best render person but wanted to see how my Jon for L'Homme rendered in Poser 13 with the updated Hivewire Cat's Cycles texture set up.  Very nice and very happy that Jon renders well.  I may return to my character packs when time permits and release some free Cycles updates for the skins and eyes.  I'm still finding my way with Cycles and testing allot on my newest character for L'Homme, Eliezer, a Latin man.  I really like developing for LH but am looking forward to Dawn 2 and eventually Dusk 2.
And yes this is a composition cobbled together in Photoshop (just the close up)  I used the Background node in Poser to bring in that really pretty path with flora, I did add in the shadow as I wasn't sure, at the time, if a shadow catcher would work with Cycles for that but apparently it does so hopefully won't have to fake ground shadows.  I just did a quick object selection in PS and then inverted and used the Burn brush tool to put it in.  Little dark but worked!
My Store is HERE
hborre ( ) posted Fri, 07 April 2023 at 10:50 AM
Online Now!
Y-Phil posted at 8:37 AM Fri, 7 April 2023 - #4461099
The PhysicalSurface node has a Volume connector.
Y-Phil ( ) posted Fri, 07 April 2023 at 11:37 AM
hborre posted at 10:50 AM Fri, 7 April 2023 - #4461116
You're right I just forgot...
And there are slight differences, for example: the PoserSurface shows the back boundary of the capsule for I used
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
shvrdavid ( ) posted Fri, 07 April 2023 at 12:03 PM · edited Fri, 07 April 2023 at 12:03 PM
More doodles and shader tweaks.
RedPhantom ( ) posted Fri, 07 April 2023 at 12:36 PM
Site Admin
Finally was able to get a render with the fog. I tried all three suggestions made, but it wouldn't render if I was using the hdri on the background. I had to switch to the environsphere.
hornet3d ( ) posted Fri, 07 April 2023 at 1:46 PM · edited Fri, 07 April 2023 at 1:46 PM
Working without lights can be challenging, but fun.
Wilks ( ) posted Fri, 07 April 2023 at 3:18 PM
I am very impressed!
The upgrade is worth it.
GiveitUp ( ) posted Fri, 07 April 2023 at 4:53 PM
Content Advisory! This message contains violence
V5t24TLpJ0pr7RctqLxYD1laJHZf0BzZSQlF3GOt.jpgAnd I almost forgot about my mother-in-law... and then along came Poser 13.
GiveitUp ( ) posted Fri, 07 April 2023 at 5:16 PM
Ok... that's a little bit better. I played around a bit on the denoiser... grunt.JqkJst6piHB1pQgexqXG9g1CVwHGvak6lkIi82I1.jpg
Snarlygribbly ( ) posted Fri, 07 April 2023 at 5:31 PM · edited Fri, 07 April 2023 at 5:31 PM
So… I did my first render in gazillions of years, it seems :)
This was just to check that stuff was properly installed and working.
A few folk from an ancient runtime got to play together on a hillside.
I have to admit - I've almost forgotten how to use Poser, but it's coming back to me.
Free stuff @ https://poser.cobrablade.net/
Y-Phil ( ) posted Fri, 07 April 2023 at 5:47 PM
Snarlygribbly posted at 5:31 PM Fri, 7 April 2023 - #4461198
It's really, really cool to see you playing along with Poser... Yayyy
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
adp001 ( ) posted Fri, 07 April 2023 at 8:01 PM
Maybe a little candlelight will help lighten things up...
JoePublic ( ) posted Fri, 07 April 2023 at 8:38 PM
Well, I'm still not liking Superfly enough to switch, but me and Vicky 1 Low Resolution are enjoying the improved Firefly speed quite a lot.
RedPhantom ( ) posted Fri, 07 April 2023 at 9:40 PM · edited Fri, 07 April 2023 at 9:40 PM
Site Admin
Had to play with the prime freebie. It doesn't have the Superfly shaders so I updated those.
Rhia474 ( ) posted Fri, 07 April 2023 at 9:46 PM
Soo pretty!
hornet3d ( ) posted Sat, 08 April 2023 at 5:08 AM
Working without lights can get difficult, but it is fun.  Poser 6 with some post work.
ghostship2 ( ) posted Sat, 08 April 2023 at 9:39 AM
@hornet3d I have a free light set that includes a light set that lights the scene while you work but does not light anything when you render.
https://www.renderosity.com/freestuff/items/86815/studio-lights-for-poser-12-and-poser-11
GiveitUp ( ) posted Sat, 08 April 2023 at 9:55 AM
Not the best textures for the ship.....a pity.
Win 11, Poser 13, OptiX high - approx. 45 seconds, PostFX denoiser 0.5 etc.  Ryzen 9 5950X 16-Core, 64GB, RTX 2070 Super....
hornet3d ( ) posted Sat, 08 April 2023 at 10:02 AM
ghostship2 posted at 9:39 AM Sat, 8 April 2023 - #4461268
Thank you for that, it will certainly be useful.
jroulin ( ) posted Sat, 08 April 2023 at 10:36 AM · edited Sat, 08 April 2023 at 10:36 AM
Online Now!
Played a little with Dawn and Walk Designer and quickly came to this. It seems to work very well with Poser 13.
hornet3d ( ) posted Sat, 08 April 2023 at 11:21 AM
jroulin posted at 10:36 AM Sat, 8 April 2023 - #4461276
That does look good.
hornet3d ( ) posted Sat, 08 April 2023 at 11:29 AM
This is the scene that my graphics card did not like, the log stated problems with a texture but with so many where do I start.  Thankfully it rendered in with CPU.
Rhia474 ( ) posted Sat, 08 April 2023 at 11:36 AM
Yeah, I came to the conclusion that P13 does not like anything that is pre-P13 texturewise to render with graphics cards. Something with the new render engine is even more hostile to old setups then P12 was and even texture converter scripts don't help. Or are inconsistent.
It must be something with Physical vs. Cycles Surface. This may need at least a short manual/ documentation from those who understand the differences for us casual users, because it will cause quite a noise. There is a LOT more work to be done to convert to render correctly.
DCArt ( ) posted Sat, 08 April 2023 at 12:02 PM · edited Sat, 08 April 2023 at 12:04 PM
hornet3d posted at 11:29 AM Sat, 8 April 2023 - #4461288
What scene is that, hornet?   And can you PM me with your email addy so that I can get a copy of that error log?
hborre ( ) posted Sat, 08 April 2023 at 12:03 PM
Online Now!
I feel that Poser will move away from the PoserSurface and replace it with the PhysicalSurface node.  There are fewer parameters to keep track and the connections are more efficient.  I will need to run Firefly renders with both PoserSurface and PhysicalSurface but from what I see, the PhysicalSurface node produces better results.
DCArt ( ) posted Sat, 08 April 2023 at 12:07 PM · edited Sat, 08 April 2023 at 12:17 PM
hborre posted at 12:03 PM Sat, 8 April 2023 - #4461294
There is an awful lot of content out there that uses PoserSurface root, I suspect it will remain for backward compatibility with older content. The tricky part will be getting content creators fired up to use it.
And for the record, Physical Surface root works MUCH better with PBR Metal and Roughness maps than the Spec and Gloss maps used in PoserSurrace.
DCArt ( ) posted Sat, 08 April 2023 at 12:10 PM
Rhia474 posted at 11:36 AM Sat, 8 April 2023 - #4461291
Alt Diffuse and Alt Spec on the PoserSurface node might be suspect. There really isn't an equivalent on the Cycles-friendly root nodes (Physical Surface and Cycles Surface).
Rhia474 ( ) posted Sat, 08 April 2023 at 12:22 PM
But here is the thing. Even after I used the Physical Surface root for conversion, those scenes still rendered black. Used Ken1171's script specifically. That led me to the conclusion that there must be something P13's Sfly renderer using GPU or OptiX does not like even in the PS node.
Will test a bit further tonight, but based on this morning's tests, that was my preliminary observation.
DCArt ( ) posted Sat, 08 April 2023 at 12:28 PM
Rhia474 posted at 12:22 PM Sat, 8 April 2023 - #4461297
Can you point me toward a prop in the included content that you tried to convert with Ken's script? I have that as well and can investigate a little more to see if I can reproduce it.
Rhia474 ( ) posted Sat, 08 April 2023 at 12:31 PM · edited Sat, 08 April 2023 at 12:34 PM
Oh ,no, this was not included content and I think that's at the root of the thing. There is a LOT of content people (like me) purchased here or elsewhere for good money that are solid items but cannot use them under current conditions. Let me see what I got as an example.
And the maddening part of it is, there is no consistency. Some old scenes I open render fine, some immediately render black. It looks as if there must be some particular material settings that causes this.
DCArt ( ) posted Sat, 08 April 2023 at 12:32 PM · edited Sat, 08 April 2023 at 12:35 PM
Rhia474 posted at 12:31 PM Sat, 8 April 2023 - #4461300
Does it render in Firefly? (And if you can give a link to the item in the store I'll see if I can nab a copy)
DCArt ( ) posted Sat, 08 April 2023 at 12:36 PM · edited Sat, 08 April 2023 at 12:36 PM
Yes, that is why I mentioned that things connected to the Alt Diffuse and Alt Spec connections in Poser Surface might be suspect. Not all old materials use those connections, and the ones that do NOT might be the ones that seem to convert OK. But I wanted to try to verify that theory by seeing if I can reproduce the conversion.
Rhia474 ( ) posted Sat, 08 April 2023 at 12:40 PM
Firefly chokes on hair for me, like it always did, but otherwise the two scenes I tried render, no problem.
Rhia474 ( ) posted Sat, 08 April 2023 at 12:42 PM
Yeah, give me a few hours so I can get some links and such when I'm not with family and will send some linkies. THANKS!
ghostship2 ( ) posted Sat, 08 April 2023 at 12:59 PM · edited Sat, 08 April 2023 at 12:59 PM
I have not been using included shaders for anything for years because of problems. Even before Superfly I'd see crazy node setups that did not make any sense and now that I'm rendering using a GPU that craziness just equates to an OPTIX crash or something rendering total black. It's one of the reasons I really hate buying/using large scene props from the marketplace. None of the mats are optimized for Superfly or worse, they generate a crash.
When I do use something I have to replace EVERY material with my own. Here is anexample
Rhia474 ( ) posted Sat, 08 April 2023 at 1:07 PM
Right, sure, but what if you HAVE those because you work on certain genres and you NEED them? I mean, it's not that I can pick and choose for historical furniture for P13?
Rhia474 ( ) posted Sat, 08 April 2023 at 1:16 PM
@DCArt, I just tested Montespan Interior Scene:
https://www.renderosity.com/marketplace/products/97411/montespan-interior-scene
I used Go Physical to convert every prop into Physical Surface. It *still* remders black both with OptiX and in GPU.
13:05:06 - SuperFly: Illegal address in CUDA queue copy_from_device (integrator_shade_surface integrator_sorted_paths_array prefix_sum)
13:05:06 - SuperFly: Rendering time: 14.84 seconds.
13:05:06 - SuperFly: Rendering memory: 3684 MB.
13:05:10 - Analytics: Ending timer for Render:SuperFly
DCArt ( ) posted Sat, 08 April 2023 at 1:21 PM
Gorgeous set Rhia, it goes back to Poser 5/6 days (eeeekkkkkkk) .... when converting the figures, each generation I went back had more challenges. So this should be a fun one LOL. Still suspecting Alt Diffuse and Alt Spec connections not converting, but we shall see. 8-)
Rhia474 ( ) posted Sat, 08 April 2023 at 1:33 PM
I don't see any of those connections in my Matroom active...
DCArt ( ) posted Sat, 08 April 2023 at 1:43 PM
Rhia474 posted at 1:33 PM Sat, 8 April 2023 - #4461315
Right I don't either. These shaders are ultra ultra ultra basic.  And the ones that I tried don't render black after I run them through Go Physical.
Are there any props in particular in that set that are giving you problems that I should look at?
GiveitUp ( ) posted Sat, 08 April 2023 at 1:45 PM
OptiX Ultra Caustics  without PostFXkc98uJplrPtyZotqS92XTDSiKbnhcx3pPjMODeSr.jpg
Rhia474 ( ) posted Sat, 08 April 2023 at 1:45 PM
I would need to do a one-by one by prop. I loaded it as a whole scene. Need some time for that.
hornet3d ( ) posted Sat, 08 April 2023 at 1:48 PM
DCArt posted at 12:02 PM Sat, 8 April 2023 - #4461293
The location is Hostile Surface recently put on the market by Coflek-gnorg but that is not what is creating the issue as Coflek-gnorg has been providing both Firefly and Superfyl textures for his products for some time.  The scene is populated with content from a number of different venders and there is something my graphics cards does not like.
