(Last Updated: 2025 Feb 09 3:18 am)
Color Map and Bump Map are just simple Image node. You have two: the classic:
And the Cycles-based:
The difference between the two are some parameters available in the Cycles version and not in the other. At the beginning, the classic one is easier to use.
You can change the label of a node by simply double-clicking on its title, so that you may enter what you want:
Abuse of Cycles nodes, not Double BigMac's...
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Win11 on i9-13900K@5GHz, 64GB, RoG Strix B760F Gamng, Asus Tuf Gaming RTX 4070 OC Edition, 1 TB SSD, 6+4+8TB HD
👿 Mac Mini M2, Sequoia 15.2, 16GB, 500GB SSD
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
Afrodite-Ohki posted at 4:18 PM Thu, 13 April 2023 - #4462090
Lol...Wow, Y-Phil, I guess someone was hungry when explaining stuff 🤣
I saw the word Beginner so I thought that snapshot would be easier to understand, and I do love use Flameshot for this...
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
Thank you for the explanation, Y-Phil. I've got it working on Vicky 4 and she's looking better now.
One minor problem. I click on Subsurface Radius, update the numbers as shown and press return, but if I click on it again to check the numbers they have gone back to how they were at the start. I've tried not pressing return but clicking somewhere else but it still ignores my changes. Is there some trick to updating this?
Make sure you are entering all three values separated by commas before pressing enter. If you try to enter a single value, it won't know what to do with it and might throw it away.Thank you for the explanation, Y-Phil. I've got it working on Vicky 4 and she's looking better now.
Oops sorry I didn't get your joke correctly as I was tired. I don't why I'm using this all the time, I probably eat one each 5 or 10 years...Wow, Y-Phil, I guess someone was hungry when explaining stuff 🤣
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
Y-Phil posted at 3:24 AM Fri, 14 April 2023 - #4462135
Because using Monty Python references in Python tutorials was already taken?Afrodite-Ohki posted at 4:18 PM Thu, 13 April 2023 - #4462090
You wanted to give them a fast response, filled with information?
You wanted to get to the meat of the matter?
Or given how tired you were, perhaps you were simply fried?
Thalek posted at 10:34 AM Fri, 14 April 2023 - #4462151
Too tired indeed, to understand correctly Afrodite Ohki's funny remarkY-Phil posted at 3:24 AM Fri, 14 April 2023 - #4462135
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
ChromeStar posted at 10:53 PM Thu, 13 April 2023 - #4462117
peter_wade posted at 6:41 PM Thu, 13 April 2023 - #4462101I've had another go at this. I was entering the three numbers but the key icon was highlighted, I must have activated it accidentally when trying to click on the values. I tried to switch this off by de-selecting animated from the context menu but it still wouldn't accept my changes. Then I created a new node and this worked OK.Make sure you are entering all three values separated by commas before pressing enter. If you try to enter a single value, it won't know what to do with it and might throw it away.Thank you for the explanation, Y-Phil. I've got it working on Vicky 4 and she's looking better now.
I'll do some more tests to try and figure out how this works. If I can't find a way to re-enable editing of the values I'll put a ticket in for it.
My brain is even worse when I'm hungry 🤣🤣🤣Thalek posted at 10:34 AM Fri, 14 April 2023 - #4462151
Feel free to call me Ohki!
What a relief! I am not alone in this case 😂My brain is even worse when I'm hungry 🤣🤣🤣
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
Oh I've read somewhere that to help our tiring brains, there's one option among others: the music, either played or listened
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
DCArt posted at 1:41 PM Mon, 17 April 2023 - #4462481
Yeah why is it I can remember the lyrics from 50+ year old songs, but not what I was reaching for the mouse to do? LOL
Looks like you're more interested in the sixties than in your mouse
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
I am trying to setup the Superfly skin shader described in another thread here but when I try to add the nodes I can't find the Redfilter or Bump2Normal nodes anywhere in any of the menus or sub-menus. Do I need an add-on to get these or am I doing it wrong?
Also, I can't find a Color Map or Bump Map node but I can find an image_map node. Is this the same thing?
