Thu, Dec 12, 9:43 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 12 3:30 am)
Subject: Control Poser dials with Sounds/Music script
Uncanny_Film ( ) posted Mon, 24 April 2023 at 10:17 AM · edited Thu, 12 December 2024 at 9:37 AM
Wasn't there some software or application that allows you to convert sound/music into a format to be used inside a poser to control the dials?
You would import a sound into this application and it will control Posers dial according to the sound itself.
Thanks
Win10 - AMD 2nd Gen Ryzen Threadripper 2950X, 16-Core, 32 Thread 4.4 GHz - 128GB Ram - X2 GeForce RTX 3060 Ti - 3D-connexion
Poser 12 | Octane Render |  Real-Flow | 3DCoat | Speed Tree | Adobe Premiere  |  Adobe After Effects |  Adobe Audition |  Adobe Photoshop
primorge ( ) posted Mon, 24 April 2023 at 11:44 AM
Sounds like you are talking about Daz's Mimic application.
Uncanny_Film ( ) posted Mon, 24 April 2023 at 4:10 PM
primorge posted at 11:44 AM Mon, 24 April 2023 - #4463237
Does it work with props? Where can I find it?
primorge ( ) posted Mon, 24 April 2023 at 5:20 PM
At Daz
I don't really know much about it other than it's primarily for lip sync, requires a character (figure) configuration file for that specific figure, and syncs phonemes morph dials to imported sound files. It's like Poser's own Talk Designer.
It's easy enough to convert a prop to a figure... the rest. ?
There's probably a way to do what you want to do in Poser itself via it's animation tools that doesn't require your prop to have "lips" and phonemes per se. Someone more knowledgeable about animation could extrapolate further I imagine, here or on one of the technical forums.
It would be more helpful if you were more descriptive of what you'd like to explicitly achieve. For example an articulated record player that when a sound file is played dials the stylus to the record and turns the turntable (or vice sersa) or some such.
