Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Sep 18 2:50 am)
It's been done. It's free on ShareCG as "SnapTo for Poser 12".
HartyBart posted at 9:54 AM Mon, 24 April 2023 - #4463231
Got it.It's been done. It's free on ShareCG as "SnapTo for Poser 12".
Thanks
Win10 - AMD 2nd Gen Ryzen Threadripper 2950X, 16-Core, 32 Thread 4.4 GHz - 128GB Ram - X2 GeForce RTX 3060 Ti - 3D-connexion
Poser 12 | Octane Render | Real-Flow | 3DCoat | Speed Tree | Adobe Premiere | Adobe After Effects | Adobe Audition | Adobe Photoshop
Can someone Update this script to work with Poser 12?
Thanks.
# Snap-to
# Jan 9,06
# Copyright (c) 2006 by David G. Drumright (ockham)
# Select the 'mover' before hitting the script.
# Hit the script, then select the 'destination'.
# The 'mover' will go to the dest.
import poser
import string
scene=poser.Scene()
Mover=scene.CurrentActor()
if not Mover.IsProp() and not Mover.ItsFigure(): exit
from Tkinter import *
# Next section is TK
class App:
def __init__(self, master, textMessage):
self.master = master
master.title("Snap-to")
self.StatusEntry = Entry(self.master,width=60)
self.StatusEntry.grid(row=0,column=0)
self.master.protocol('WM_DELETE_WINDOW', self.HandleCancel)
def ShowStatus(self,S): # Just saving repetition
self.StatusEntry.delete(0,END)
self.StatusEntry.insert(0,S)
self.StatusEntry.update_idletasks()
def Update(self):
if scene: scene.ProcessSomeEvents(1)
self.ShowStatus("%s is mover. Waiting to select destination..." % Mover.Name())
Dest=scene.CurrentActor()
# Two ways to be a different object. Either the Name is
# different, or the part is on a different figure.
Diff = 0
DF=Dest.ItsFigure()
MF=Mover.ItsFigure()
if string.upper(Dest.Name())=='BODY': Diff = 0
# Somewhat tricky.
# It appears that the BODY gets quietly selected very briefly before you
# select a part, so we can't act on the BODY.
elif Dest.Name() != Mover.Name(): Diff = 1
elif DF and MF and (DF.Name() != MF.Name()): Diff = 1
if Diff:
DestX=Dest.ParameterByCode(poser.kParmCodeXTRAN).Value()
DestY=Dest.ParameterByCode(poser.kParmCodeYTRAN).Value()
DestZ=Dest.ParameterByCode(poser.kParmCodeZTRAN).Value()
else:
scene.DrawAll()
# Locate actual center of dest.
Geom=Dest.Geometry()
MinX= 10000.0
MinY= 10000.0
MinZ= 10000.0
MaxX=-10000.0
MaxY=-10000.0
MaxZ=-10000.0
for v in range(Geom.NumVertices()):
WV=Geom.WorldVertex(v)
if WV.X() > MaxX: MaxX=WV.X()
elif WV.X() < MinX: MinX=WV.X()
if WV.Y() > MaxY: MaxY=WV.Y()
elif WV.Y() < MinY: MinY=WV.Y()
if WV.Z() > MaxZ: MaxZ=WV.Z()
elif WV.Z() < MinZ: MinZ=WV.Z()
DestX=(MaxX+MinX)/2.0
DestY=(MaxY+MinY)/2.0
DestZ=(MaxZ+MinZ)/2.0
Mover.ParameterByCode(poser.kParmCodeXTRAN).SetValue(DestX)
Mover.ParameterByCode(poser.kParmCodeYTRAN).SetValue(DestY)
Mover.ParameterByCode(poser.kParmCodeZTRAN).SetValue(DestZ)
scene.SelectActor(Mover) # return to the item we're trying to move
scene.DrawAll()
self.master.destroy() # Done.
else: # Keep watching
root.lift()
root.after(100, self.Update)
def HandleCancel(self):
# Activate the loop
root = Tk()
app = App(root, '')
app.Update()
root.mainloop()
# End TK loop.
