Thu, Oct 3, 2:20 PM CDT
Renderosity Forums / Community Center
Welcome to the Community Center Forum
Community Center F.A.Q (Last Updated: 2024 Sep 28 10:18 am)
Forum news, updates, events, etc. Please sitemail any notices or questions for the staff to the Forum Moderators.
Subject: Editing a gallery item with several pictures... all but one get deleted
3dcheapskate ( ) posted Sat, 22 April 2023 at 4:26 AM · edited Thu, 03 October 2024 at 12:26 PM
I've had this happen a couple of times over the past week or two.  I'd estimate that it happens around 5% of the time or less, but I can't yet tie it down to anything particular that I' m doing  - adding pictures, deleting pictures, and/or editing test.
The 3Dcheapskate* occasionally posts sensible stuff. Usually by accident.
And it usually uses Poser 11, with units set to inches. Except when it's using Poser 6 or PP2014, or when its units are set to PNU.
*also available in ShareCG, DAZ, and HiveWire3D flavours (the DeviantArt and CGBytes flavour have been discontinued).
CHMedia ( ) posted Sat, 22 April 2023 at 7:52 AM
I will post your issue to our issue tracker. Thank you for reaching out.
3dcheapskate ( ) posted Sun, 23 April 2023 at 12:16 AM
When It happens again I'll post back here. I'll try to be more specific about what I was doing but, as you'll appreciate, when I'm updating a gallery item recording what I do step by step for possible bug-reporting isn't at the front of my mind.
Possibly related. A couple of days ago I was editing a gallery item. I removed one image, added a few new ones, and then saved. I got a red error message - I can't remember what it said, but remember thinking that it obviouslt doesn't like you removing an image and adding images at the same time.
lauraguo ( ) posted Wed, 26 April 2023 at 4:29 PM
Thank you for reporting this issue.
We've looked into it, and it appears that it only happens when you edit a gallery item whose multi-image slots are all filled out. So, if you click "Edit" on a gallery item and it already has all the multi-image slots filled out, clicking "Update" will cause the issue you've notice.
This should be fixed sometime tomorrow, I'll let you know when it happens.
3dcheapskate ( ) posted Thu, 27 April 2023 at 12:09 AM · edited Thu, 27 April 2023 at 12:09 AM
That would probably fit - I may have been trying to just edit the description of a gallery item that had all 15 image slots filled.
Thanks for looking into it.
lauraguo ( ) posted Thu, 27 April 2023 at 9:58 AM · edited Thu, 27 April 2023 at 9:58 AM
This should now be fixed--please let us know if it happens again. Thank you for your patience!
