New Poser Users Help F.A.Q (Last Updated: 2025 Jan 26 12:54 pm)
OK. Materials Room seems appropriate, but it is totally new territory for me.
I have a private Runtime called "Vic 4" for all my Victoria 4 related stuff. The customized textures are in the Textures folder in that Runtime. However, when I get to the Materials Room, with my modified Victoria 4 figure selected, there don't seem to be any Materials as bobbesch so helpfully suggested.
How do I find the textures that I want?
OK! Thanks to both of you. You sure got me on the right track!
The process I used in the Material Room was as follows:
1. Select the body part. That brings up the little "Color_Texture" window.
2. Click on the value for the Image Source. That brings up the "Texture Manager" window.
3. Click on the "Browse" button. That brings up the file selection window.
4. Browse through the files until I found the texture I wanted. Double click on that.
5. Click on OK, and the new texture is applied.
It's a little tedious to fro this for each of about a dozen parts, but it works!
Many thanks!
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Win11 on i9-13900K@5GHz, 64GB, RoG Strix B760F Gamng, Asus Tuf Gaming RTX 4070 OC Edition, 1 TB SSD, 6+4+8TB HD
👿 Mac Mini M2, Sequoia 15.2, 16GB, 500GB SSD
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
Change the Diffuse color chip on the PoserSurface to white for all the skin textures, that was a hack from the older versions. Also, turn off the ambient value, set that to zero, and change the chip to black. Again, that was a hold-over hack that is no longer necessary. If you use any greyscale maps like a specular, a bump, a displacement, etc., select and change the custom Gamma value to 1 in the Texture Manager, otherwise, you will see weird effects.
I am just getting back into Poser after a long hiatus. I was active in the Poser 4 era, and now I'm trying to get back-- taking advantage of the free 21-day trial of the Mac version of Poser 12, to see if I can do it. So far, I'm doing pretty well, but I am stuck on one place at this point.
I bought Girl Next Door 4.2 and a couple of other figures. I have been able to INJ the Girl Next Door Body into Victoria 4, and INJ the head for one of the other figures into V4. Now I would like to apply a customized set of body/face textures to all parts of the combined figure.
Many thanks for any tips on how to get started applying the textures.
