(Last Updated: 2025 Feb 12 10:34 pm)
If you submit a Ticket on this please include the Poser log window. If the GPU grays out there should be an error in the log. Also once a render fails in GPU it needs to be reset and right now the only way is to exit Poser and Relaunch Poser. So launch Poser, render the offending scene and copy the text out of the log window. That will help us find if it's a bug in Cuda or the scene was just too big to fit on GPU memory.
Sometimes when I render a scene with either the GPU or the Optix selections I get a blank gray screen when it gets done.
The rendering process doesn't show like normal.
When I choose the CPU selection it renders fine, but it is a slow process.
The GPU I'm running is a NiVidia RTX2070 with Max Q Design and the CPU is an Intel Core i9 - 10885H @ 2.4 GHz with 32 gig of ram and 31.8 gig available.
Any help would be greatly appreciated.
