Community Center F.A.Q (Last Updated: 2024 Sep 28 10:18 am)
This would appear to have been fixed ? Can you confirm ?
The 3Dcheapskate* occasionally posts sensible stuff. Usually by accident.
And it usually uses Poser 11, with units set to inches. Except when it's using Poser 6 or PP2014, or when its units are set to PNU.
*also available in ShareCG, DAZ, and HiveWire3D flavours (the DeviantArt and CGBytes flavour have been discontinued).
The software seems to expect you either to add images, or to remove images, but not both together.
When editing a gallery item if you first remove an image and then add a new image you get the error below when you submit.
