(Last Updated: 2024 Nov 25 10:18 am)
tim posted at 2:10 PM Fri, 19 May 2023 - #4465797
Hm, that's interesting. If I understand you correctly, an authorized machine will be forgotten after a period of time? I was under the impression that everytime Poser is getting started, it sends a handshake request to the license server to validate the installation on the current machine. If this is not the case, I only have to wait for the machine id to get expired before I can install and use Poser on other hardware or on a fresh installed Windows? That would explain why I was having this issue. I have reinstalled my OS on the same hardware several times in the last two months and each install had caused a new machine id, right?"Seats in Use" is defined as number of unique machine-ids from which Poser has validated the license in the last 7 days. So machines don't get deauthorized, they age out of the window for consideration.
@Tim, thank you for the clarification.
Part of those spec's is probably the OS that is running on said hardware, right?
I ask this because I run in this trouble after testing Poser 13 with it's license activated under an Linux OS.
Since the tests turned out negative, I went back to Windows 10.
My guess is that Poser was still marked as activated under Linux regardless of the fact that I deinstalled Linux and installed Windows 10 on the same hardware.
Would you agree on this?
Hi fellow Poser User's. I have a quick question about managing the license key of Poser. I recently run into trouble because the numbers of open seat's for my Poser license was reached. I contacted the help desk on Poser Software Website and they helped me out with this. As far as I know, I can install Poser on three different machines but only run one at a time. I guess, my question is, if I uninstall Poser on my current machine, does it get automatically noticed by the licence server and opens a seat for another installation? I could had open a ticket at Poser Software to ask them about it, but then I thought I should do it in this forum. Thank in advance.
