Forum Moderators: RedPhantom
I'm surprised that you even got her into Bullitt Physics. That heavy outline is her DAZ subdivision still active, you should turn that off. I'm assuming this is P11. What settings do you have for the Preview, Firefly or Superfly? Does the Material Room still look the same when you switch? Have you tried another G8 figure just in case it's a corruption setting in?
Alright, I've been trying to fix this issue myself and now I'm going to ask for public help. As you can see in my image displays, I open Genesis 8 in Poser using DSON. I also use the Genesis 3/8 Expression Updater. When I take it through Bullet, everything looks right on Genesis 8 until I select soft body dynamics. Then her skin texture turns to a dark color that does not show her png texture. Can somebody show me what to do to possibly fix this or make her skin normal again? I've used bullet with Genesis 8 before and it did work.
