Tue, Jan 21, 4:11 PM CST
Renderosity Forums / Poser 13
Welcome to the Poser 13 Forum
(Last Updated: 2025 Jan 21 8:54 am)
Subject: !? Point Lights Not Working ?!
DownTown37 ( ) posted Sat, 10 June 2023 at 5:28 PM · edited Tue, 21 January 2025 at 3:37 PM
Point lights seem not to be working right in Poser 13 Superfly. If changing the "Dist End"  "Dist Start"  it does not show any effect like it does in Firefly, the point light seems to be  lighting up the whole Environment like a Infinite light. Might just be on my side, would be good to know if someone else is having the same issues with this light in superfly. Or is it just not supposed to be a light to be used in superfly?
nerd ( ) posted Sat, 10 June 2023 at 5:53 PM · edited Sat, 10 June 2023 at 5:53 PM
Forum Moderator
The start and end distance controls only work for FireFly Renders. SuperFly (Cycles) represents light in a more realistic way. The setting you probably want is the Light attenuation property on the light's properties page. This will make the light intensity drop off in a realistic way.
DownTown37 ( ) posted Sat, 10 June 2023 at 6:08 PM · edited Sat, 10 June 2023 at 6:10 PM
Yes Perfect! so no more issues, works just at it should this way. Thank you :)
(Issue solved)
hborre ( ) posted Sun, 11 June 2023 at 6:50 AM
Online Now!
I addressed this answer in another post.
shvrdavid ( ) posted Sun, 11 June 2023 at 4:25 PM
Actually, it wasn't addressed at all. Because there are ways to duplicate every Firefly light in Superfly
You can do Firefly style point lights in basically any render engine, including Superfly.
The difference, is that you don't use a light to do so in Superfly.
There are some issues with lights in Superfly compared to Cycles, because it is missing a node from cycles.
But fear not, there is a way around it. Actually, multiple ways around it.
Here, I am using a ball prop scaled down to 10%. Which is very close to the size of the Poser point light. It is just out of the scene to the right, not that far from the figures face.
Poof, point light just like in Firefly that cuts off exactly at the distance you set it too..
Yes you need to change some things to get the different falloffs.
This is Monte Carlo style lighting, in Superfly. And it obviously can be done even thou other lights follow PBR..
Everyone using Superfly should learn the LightPath node........
Y-Phil ( ) posted Mon, 12 June 2023 at 1:11 AM
Wow! interesting. Thank you @shvrdavid
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
RAMWorks ( ) posted Tue, 13 June 2023 at 9:04 AM
So cool!
---Wolff On The Prowl---
My Store is HERE
My Freebies are HERE
