Sat, Nov 16, 9:10 AM CST
Renderosity Forums / New Poser Users Help
Welcome to the New Poser Users Help Forum
New Poser Users Help F.A.Q (Last Updated: 2024 Nov 16 8:48 am)
Subject: how work with nose magnet?
drawn ( ) posted Wed, 14 June 2023 at 2:24 PM · edited Mon, 04 November 2024 at 9:57 AM
i got a figure close up in Face and found the magnets menu and picked Nose Magnet because I want to turn up th tip of figure's nose slightly and doesn't seem to make a difference what I do.  Help?
drawm
RedPhantom ( ) posted Wed, 14 June 2023 at 3:15 PM · edited Wed, 14 June 2023 at 3:15 PM
Site Admin Online Now!
When you load a magnet, 3 things load, 1, a magnet, 2, a magnet base, and 3,  a magnet zone. The magnet zone is a circle that poser what part of the figure (or prop) the magnet should work on. It's likely this zone isn't including the nose of the figure and needs to be moved. The reason the zone may be in the wrong place is probably you're using a figure other than P4 nude man that the magnet was created for. It's fine to use a different figure, but you'll need to move the zone
In this second picture, the zone has been moved so the nose is affected.
If you don't like the shape created, you can move the magnet itself to change how it shapes the nose.
RedPhantom ( ) posted Wed, 14 June 2023 at 3:23 PM
I'm glad you asked about this. I forget about using magnets to change the look of a figure. My main use for them is to put dents in seats that have people sitting on them so the cushion doesn't look rock hard.
vikinglady ( ) posted Wed, 14 June 2023 at 5:35 PM
Avidly taking notes... Favorited in browser.
drawn ( ) posted Thu, 15 June 2023 at 7:30 AM
Red, thanks for clear explanation, but when I try to put Nose Magnet on my figure, it tries to search for something, an then tells me it can't find it? Do you know what it needs?
RedPhantom ( ) posted Thu, 15 June 2023 at 7:51 AM
It's looking for ball.obz That's the geometry file for the ball or the magnet zone. It might also be listed as ball.obj. My copy is in Runtime\geometries\props\. I would have thought it installed with Poser
drawn ( ) posted Thu, 15 June 2023 at 2:29 PM
RTvVO9qibJaA9oWXRgDepnR4i69OXafbqohhixp5.pngRed, i got this far, but how do i actualy affect the nose?
don
RedPhantom ( ) posted Thu, 15 June 2023 at 7:44 PM
You need to move the magnet zone over the noze
