Mon, Jan 20, 10:51 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 20 7:34 am)
Subject: Pose 13 scatter weirdness
sturkwurk ( ) posted Thu, 13 July 2023 at 9:00 AM · edited Mon, 20 January 2025 at 10:49 AM
Ok let's get some details out first.
Victoria 4 - using ezskin3 for the base setup
This does NOT happen in poser 12.
I can take a Poser 12 file without it happening, open it in Poser 13 and it happens.
there are weird blow out to white spots happening to select jpg textures in poser 13's scatter node.
Below is the Poser 12 render...
then below is Poser 13 -of the same exact file
I'm not worried about the brightness and skin, my problem is the pupil/iris.
At first, I thought it was picking up some reflective white surface, but after pulling out a lot of hair, I discovered if I just used a different texture it would go away.
then I noticed this in the material room...
WEIRD blowout spots that just happen to be exactly where the spot is on her eyes....
but if I plug in a different texture...
I thought maybe there's some difference in the color settings of the jpgs... but I can overlay the "bad" one over the "good one" in photoshop and make a new jpg that still acts weird.
SO- for now I can just find another texture that's close enough as a workaround... but I'd really like to find out what the culprit is and how to fix it.
Thanks!
I came, I rendered, I'm still broke.
hborre ( ) posted Thu, 13 July 2023 at 9:51 AM
Change the Scatter node SubsurfaceMethod to RandomWalk or RandomWalk fixed and re-render.
sturkwurk ( ) posted Thu, 13 July 2023 at 10:13 AM
hborre posted at 9:51 AM Thu, 13 July 2023 - #4469948
I tried that! I even reloaded the textures after trying each one of those - it didn't work. :(
sturkwurk ( ) posted Thu, 13 July 2023 at 10:51 AM
b8q4lCzFJgGNNKLQTtwdTFEeCVmlxRl3NBglRxpx.png I have it doing the same thing on some skin textures. That's not supposed to be white on the eyeshadow.
hborre ( ) posted Thu, 13 July 2023 at 11:31 AM
Suggestion, plug the problem diffuse map directly into the Scatter Node and note if there is a difference.  Also, change the HSV node for the HSV_2 node, that's the node you should be using as a replacement.
BTW, Firefly or Superfly?  You did not specify which render engine you are using.
sturkwurk ( ) posted Thu, 13 July 2023 at 11:44 AM
hborre posted at 11:31 AM Thu, 13 July 2023 - #4469956
Thanks for getting back to me, Sorry - This is Superfly.
I did try plugging the map directly into the scatter node - it still had the problem.
the most curious thing is - I can find other textures that work just fine.
sturkwurk ( ) posted Thu, 13 July 2023 at 12:46 PM
if I could figure out why some textures do it and others don't... and it was something I could alter on the offending textures... I'd be all for it.
hborre ( ) posted Thu, 13 July 2023 at 1:11 PM
In comparison with the images you provided, there shouldn't be any reason, under the same set of conditions, that one set of textures works and the other doesn't.  There are a good number of users that are shying away from EZSkin and conforming to using the PhysicalSurface node or Cycles node for Superfly rendering.  Snarly is considering revamping EZSkin to use the current Superfly alternatives, I'd be willing to test run the prototypes.
Ghostship has created Superfly-specific eye shaders for V4 and, IIRC, you should find them in the free section.
sturkwurk ( ) posted Thu, 13 July 2023 at 1:55 PM
hborre posted at 1:11 PM Thu, 13 July 2023 - #4469967
exactly - I can't find the reasoning on why some work and others don't, but they are consistent.
sturkwurk ( ) posted Thu, 13 July 2023 at 3:59 PM
I just tried saving one of the jpgs that acts up as a Png, bmp, PSD... they all still do the same thing
RedPhantom ( ) posted Thu, 13 July 2023 at 6:24 PM
Site Admin Online Now!
I've seen this too. I had meant to investigate it more and then post here to see if others have seen the same issue, then report it as a bug. Unfortunately, RL has been a bit crazy lately and I forgot. And it's not just on Vicky. It was either M4 or L'homme I was working with.
ghostship2 ( ) posted Thu, 13 July 2023 at 6:51 PM
Online Now!
@sturkwurk
I think the old EZScin3 mats are a little off in P13. I have a SSS skin thread in the P13 forum with examples and mat room materials
sturkwurk ( ) posted Thu, 13 July 2023 at 7:58 PM
RedPhantom posted at 6:24 PM Thu, 13 July 2023 - #4469997
Yes, my M4 does it also
sturkwurk ( ) posted Thu, 13 July 2023 at 8:00 PM
ghostship2 posted at 6:51 PM Thu, 13 July 2023 - #4470001
@sturkwurk
Got a link? (Love your products btw)
ghostship2 ( ) posted Thu, 13 July 2023 at 10:15 PM
Online Now!
@sturkwurk
https://www.renderosity.com/forums/threads/2978516/cycles-based-sss-skin-shader
RedPhantom ( ) posted Fri, 14 July 2023 at 10:36 AM · edited Fri, 14 July 2023 at 10:37 AM
I did some hunting this morning
These scatter nodes seem to be the problem. They turn any pure black to white. Changing any of the settings in the nodes does nothing to help. Change the black even the slightest and it works again. You can edit the actual image or you can use a mix node to make it work.
sturkwurk ( ) posted Fri, 14 July 2023 at 11:37 AM
RedPhantom posted at 10:36 AM Fri, 14 July 2023 - #4470153
that fixed it! Thank you for taking the time to figure it out!
sturkwurk ( ) posted Fri, 14 July 2023 at 11:39 AM
that was the lowest blend I found that worked... if I added one more decimal it failed.
hborre ( ) posted Fri, 14 July 2023 at 11:46 AM
Well that completely bites!!  Hopefully, the techs can integrate the patch into the new release coming out soon.  Someone did submit a ticket, did they?
hborre ( ) posted Fri, 14 July 2023 at 12:03 PM · edited Fri, 14 July 2023 at 12:03 PM
If you are using Cycles nodes, this would be the arrangement:
shvrdavid ( ) posted Fri, 14 July 2023 at 12:18 PM
I am creating a ticket on this, linking it to this thread.
RedPhantom ( ) posted Fri, 14 July 2023 at 12:20 PM
shvrdavid posted at 12:18 PM Fri, 14 July 2023 - #4470167
Thanks. I was going to do that but had some RL stuff to tend to first
sturkwurk ( ) posted Fri, 14 July 2023 at 1:10 PM
I used to test for Poser on the Smith Micro team.
eons go
ghostship2 ( ) posted Sat, 15 July 2023 at 2:01 PM
Online Now!
@sturkwurk
didn't you have a bunch of freebies here at Rendo a long time ago? I seem to remember some superhero stuff of yours that I downloaded.
sturkwurk ( ) posted Sat, 15 July 2023 at 2:32 PM
ghostship2 posted at 2:01 PM Sat, 15 July 2023 - #4470250
@sturkwurk
yep, a very long time ago :)
ghostship2 ( ) posted Sat, 15 July 2023 at 5:48 PM
Online Now!
@sturkwurk
Ask JennBlake here on Rendo if you want to get on the beta tester team
sturkwurk ( ) posted Sat, 15 July 2023 at 6:22 PM
ghostship2 posted at 5:48 PM Sat, 15 July 2023 - #4470278
@sturkwurk
Thanks, but I'm a bug magnet, but not a bug fixer. :P
Y-Phil ( ) posted Sun, 16 July 2023 at 2:16 PM · edited Sun, 16 July 2023 at 2:16 PM
sturkwurk posted at 6:22 PM Sat, 15 July 2023 - #4470284
@sturkwurk
Bug magnets are important to track the remaining ones. My boss used to be one, precisely, and that was awesome zCPVTQyonNdQpLqtICma7nFTtxfKNwE6eTVa5fy0.png
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
