Carrara F.A.Q (Last Updated: 2024 Sep 29 9:32 am)
you could delete them in the vertex room under morph but no idea why you would want to.
Just zeroing better as not gone for good.
Animation zero selection should do it depending on the figure (legacy or genesis +)
you may need to do some editing in Notepad++ then I am not very versed in editing Poser files but it is possible
I have myself used DAZ studio to create ExP injection and Remove files and Deltas using Carrara made morphs in Morphloader etc
there is a lot of documentation out there on it
at least whatever you do in Carrara will not effect your runtime so when working in DAZ studio remove your main content library from the directory and add a temporary one with just the content you need and work on that.
then you can add that to your Carrara browser too with less baggage
Hello! How to remove morph channel?
Poser can make a inj-file but can't create a morph rem-file, I used another tool to create a rem file but without success, channels just hidden but not deleted.
This not work
