Fri, Nov 22, 10:26 AM CST
Renderosity Forums / Virtual World Dynamics
Welcome to the Virtual World Dynamics Forum
Virtual World Dynamics F.A.Q (Last Updated: 2024 Nov 05 5:09 pm)
Subject: toubleshooting please
tomasball ( ) posted Thu, 05 October 2023 at 8:02 AM · edited Tue, 19 November 2024 at 10:09 PM
HI, I installed VWD on Daz studio some time ago, and have used it successfully several times.  Today I can't  make it work, and I wonder if I have had a stroke and forgotten some important part.
I make a scene with a cube and a plane.  The plane is above the  cube and the time line is 30 frames
I start VWD, select the cube and press collision and again press collision.  now the list says collision next to the cube
I select the plane, select cloth, and again press cloth.  Now it is labeled as cloth.
Now I select simulation, and then select start dynamic simulation.
It runs through the timeline, but the plane does not move at all
.  Does that sound like I'm doing something wrong?
fuqol217 ( ) posted Wed, 11 October 2023 at 4:41 AM · edited Wed, 11 October 2023 at 4:41 AM
Hi tomasball
I'm not an expert, but a keen user. What you are doing sounds ok, but when I did it I got the same result - nothing moved. Then I noticed I had GPU selected for the simulation, which seems to be a problem nowadays.
So I changed to CPU for the simulation and it worked perfectly.
Other things to consider if it still has problems (sorry if this is obvious): Try restoring default parameters; and make sure your primitives have a good number of divisions when you create them.
randolphshaw4 ( ) posted Tue, 24 October 2023 at 2:31 AM
Try restoring default parameters, and ensure that your primitives have a sufficient amount of divisions when you create them. rainbow obby
tomasball ( ) posted Tue, 24 October 2023 at 9:07 AM
It was the restore default parameters I was missing.  Thanks all.
