Community Center F.A.Q (Last Updated: 2024 Sep 28 10:18 am)
That must've been fixed, because I just downloaded it, and the zip file was named correctly..
_______________
Hello
I have just checked this on the backend, and within the newsletter that was sent out and the link is correct. The title was wrong, but it was the Classic Bedroom linked to the post. Can you try again and see if you still get the incorrect link?
Hugs
Tima
3DSublimeProductions (Tima) - Admin, Vendor, Marketplace Tester, & Vendor Education
YIKES! Isn't there a way to get R'osity sending them to you again? I thought there was, but I could be wrong.Well, another fine newsletter freebie that I can't access because newsletters aren't sent to me anymore.
_______________
If this is not in the right spot then please move it.
I just got the newsletter email that shows this item as Defend Your Realm with the Classic Bedroom image but when I try to download it the item is still staircase.
actual download:
This seems to be an ongoing problem, can someone please fix it...it most likely just needs the proper image/link changed from the previous newsletter.
