Fri, Jan 31, 5:52 AM CST
Renderosity Forums / Poser 13
Welcome to the Poser 13 Forum
(Last Updated: 2025 Jan 31 1:07 am)
Subject: Poser 13 Walk Designer
BJWxMan ( ) posted Tue, 12 December 2023 at 7:52 AM · edited Thu, 30 January 2025 at 4:26 PM
How does "Walk Designer" work in Poser 13?  I can do nothing but 'walk-in-place'.  No follow the path, no transition from starting point.  Just walk in place.  And when I use Michael 4 I get figure not supported errors.
nerd ( ) posted Tue, 12 December 2023 at 6:46 PM
Forum Moderator
First the walk path is added to your scenes from the figure menu. With a walk path in your scene you will have the option to follow a path. For the figure type be sure you have all of Poser's included content installed so you have access to all the Included walk presets. To get good results from M4 you should use either the l'Homme or Paul Figure types. Their skeleton is closest to the M4 skeleton.
BJWxMan ( ) posted Thu, 14 December 2023 at 7:06 AM
Yes, this hasn't changed significantly from Curious Labs' poser 4 through Bonderware's Poser 12.  However, when I attempt to apply "Walk Designer" in an active Poser 13 scene, I can do nothing but 'walk-in-place'.  No follow the path, no transition from starting point.  Just walk in place. 9EA4KwthpEeokVRTv9QKDN08JY5VE55lDyrc9TPF.jpg
RedPhantom ( ) posted Thu, 14 December 2023 at 7:44 AM
Site Admin
I'm getting it to work for me. It's even defaulting to the walk path option. I see you're using something called MFairweather. Is that what you renamed the figure to?
BJWxMan ( ) posted Fri, 15 December 2023 at 4:54 AM
Yes. Its an M4 figure. I did determine what the problem was.  I had parented the path to the figure.  When I unparented the path, Walk Designer worked fine.
