Fri, Jan 31, 8:59 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 31 9:45 am)
Subject: Texture creation with cut out areas fill with a mesh instead of solid color
MeInOhio ( ) posted Wed, 13 December 2023 at 9:43 PM ยท edited Fri, 31 January 2025 at 11:56 AM
I'm trying to create a texture for the bodysuit that has places on the legs where it is suppose to be a mesh. I tried creating by putting a mesh under the texture with the cutouts in Photoshop. I save it out as a png file and loaded it into Poser 13 but I'm not getting the mesh effect. So then I left out the mesh and tried it with just the texture with the holes cut out. Once I got that to work, I figured I would try to figure out how to get the mesh added. But when I load that png file into poser, the cutout areas still don't work. If I load the same texture into UV Mapper Pro, it shows texture with the cutouts. So, does Poser not use the transparency of a png file? And if not, how can I do what I'm trying to do?
Thanks.
Sunfire ( ) posted Wed, 13 December 2023 at 11:06 PM
If you do it as a true alpha png, no. Poser doesn't like them.
You have to make the background of your cut outs black, for the transparency map.
Sunfire's Creations
RedPhantom ( ) posted Thu, 14 December 2023 at 7:54 AM
Site Admin Online Now!
If you are using Superfly, you can use the cycles>texture>image texture and plug the alpha into the transparency slot. If you're using the firefly engine or the image_map under 2d textures, it doesn't work.
hborre ( ) posted Thu, 14 December 2023 at 11:29 AM
Did you create a transparency mask?
MeInOhio ( ) posted Thu, 14 December 2023 at 9:07 PM
Thanks for the replies. So do I fill the transparent places with black and then create an alpha channel for the transparent areas? Actually I to put a mesh like fabric in the holes. I have a black and white texture that would represent the mesh.
Is a transparency mask different than an alpha?
Thanks.
FVerbaas ( ) posted Fri, 15 December 2023 at 3:04 AM
Forum Coordinator
Alpha channels in .png do not work as intended, also not in Cycles node. Blender has, I understand, same issue.
One solution is to encode the transparency in your texture: let pure black (rgb=0,0,0) represent transparent and any other color opaque. Use a math.step node to filter. Signal will be white(=1) for transparent so for use in Posersurface root node you will need to invert it, by subtracting it from 1.
