Tue, Oct 1, 12:27 PM CDT
Renderosity Forums / Poser 13
Welcome to the Poser 13 Forum
(Last Updated: 2024 Oct 01 1:56 am)
Subject: New hair shader color
RedPhantom ( ) posted Mon, 01 January 2024 at 1:54 PM · edited Tue, 01 October 2024 at 12:25 PM
Site Admin
I'm working on updating my Superfly shaders for strand hair because, with the changes in Superfly, they don't look as good. Would people call this one blond or light brown?
RedPhantom ( ) posted Mon, 01 January 2024 at 1:57 PM · edited Mon, 01 January 2024 at 1:57 PM
Site Admin
Also, if anyone has any suggestions for more colors, I'm open to them. So far I have these
Sunfire ( ) posted Mon, 01 January 2024 at 2:30 PM
What about a strawberry blonde?
Sunfire's Creations
RedPhantom ( ) posted Mon, 01 January 2024 at 2:47 PM
Site Admin
I'll see what I can do. I had thought about that one and then forgot again
hborre ( ) posted Mon, 01 January 2024 at 5:28 PM
Are these colors generated with the PrincipledHair node?
RedPhantom ( ) posted Mon, 01 January 2024 at 5:34 PM
Site Admin
Some of them are, some of them are just hairbsdf combos.
Y-Phil ( ) posted Mon, 01 January 2024 at 6:55 PM
If you have one of OutofTouch's hairs, chances are that you may find a lot of standard hair colors, without any spec burned it:
Excerpt:
Currently, there's more than 160 items, scalps included.
Furthermore, one of the sets also contains alpha textures, that allows you to easily mix'n'match to bitmaps
Most of the time, I use a 0.5 X-scale when the direction of the hair is vertical.
Besides  this, Biscuits also has a really cool collection of hair bitmaps
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Mac Mini M2, Sonoma 14.6.1, 16GB, 500GB SSD
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
hborre ( ) posted Mon, 01 January 2024 at 7:40 PM
But RedPhantom is creating textures for strand hair, a different shader approach from Prop or figure hair pieces.
Miss B ( ) posted Mon, 01 January 2024 at 9:31 PM · edited Mon, 01 January 2024 at 9:32 PM
RedPhantom posted at 1:54 PM Mon, 1 January 2024 - #2985327
Looking at it at the top of her hair, I'd call it a light dusty blond, but when looking at it as a whole, I'd call it light brown.
_______________
Butterfly Dezignz
shvrdavid ( ) posted Tue, 02 January 2024 at 12:44 PM
Strand hair in Superfly is a bit odd. I still have not figured out how to reliably access the W axis across the length of it that works with multiple types of lighting. Which makes highlights a massive problem.
hborre ( ) posted Tue, 02 January 2024 at 1:47 PM
I recall that there was a YouTube video based on the Blender PrincipledHair node.  It might take some digging to find it.
shvrdavid ( ) posted Tue, 02 January 2024 at 2:55 PM
Keep in mind that particle hair is done on the x axis in Blender to set a lot up. Dynamic hair in Poser is done on the w axis more often than not.
You can do it with generated and a separate xyz on the x in Poser as well, but it just isn't the same.
BB had a thread here somewhere about that years ago. But the search is terrible here and I can not find it.
RedPhantom ( ) posted Tue, 02 January 2024 at 3:51 PM
Site Admin
What is the w axis? I'm only familiar with the x,y, and z.
shvrdavid ( ) posted Tue, 02 January 2024 at 4:06 PM · edited Tue, 02 January 2024 at 4:15 PM
W axis is the along length of dynamic hair. BB did a post with an explanation of it years ago, but I can not find it with the search here.
Dynamic hair uses 4 axes. W,X,Y, and Z.... X and Y map where the hair comes out of the scalp. Which is why you could use a texture in firefly to make strands differing colors based on where they were on the scalp. I don't recall what Z does, and W is the along length of the hair. Basically if you want to change something (color, highlight, etc) along the length, you do it on W.
Y-Phil ( ) posted Wed, 03 January 2024 at 6:28 AM
shvrdavid posted at 4:06 PM Tue, 2 January 2024 - #4479904
The first idea that comes to my mind is that Z "could be" a kind of altitude: z > 0 would allow to start the hair above the scalp, hence the expression "pulling out one's hair". 4HxWAgqVKktQwGb5RNSbwTCPjLNifVdVf9igc8NO.gif
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
shvrdavid ( ) posted Wed, 03 January 2024 at 11:58 PM
I still don't remember what the Z axis does. I think BB's post was on Runtime as well, which would be why I cant find it here.....
I would have to play with it to remember.
RedPhantom ( ) posted Thu, 04 January 2024 at 2:20 PM
Site Admin
Here's what I have so far. I've made extra glossy versions of them too as I've heard some say they prefer that. Does anyone have any other suggestions?
hborre ( ) posted Thu, 04 January 2024 at 2:47 PM
Have you considered color-dyed hair like blues, greens, and reds to start?
RedPhantom ( ) posted Thu, 04 January 2024 at 3:14 PM
Site Admin
I was thinking about doing a second set with those. I want to get creative with those, so it may take a little longer to test.
