Fri, Jan 24, 6:31 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 23 9:03 pm)
Subject: Superfly Rendering Settings
arrow1 ( ) posted Fri, 05 January 2024 at 2:50 PM · edited Mon, 20 January 2025 at 7:29 AM
Is there a tutorial on Superfly Render Settings? I would like to get the best out of La Femme 2! I am used to rendering in Firefly! Cheers
Custom built computer 128 gigs RAM,4 Terabyte hard drive, NVIDIA RTX 4060 TI 16 GIG Gig,12 TH Generation Intel i9, Dual LG Screens, 0/S Windows 11, networked to a Special 12th Generation intel I9, RTX 3060 12 Gig, Windows 11,64 gigs RAM, Dual Phillips Screens, 2 Terabyte SSD Hard Drive plus 1 Terabyte Hard Drive,3rd Computer intel i7,128 gigs ram, Graphics Card NVIDIA RTX 3060 Gig,1 Terabyte Hard Drive, OS Windows 11 64 Bit Dual Samsung Syncmaster 226bw Screens.Plus INFINITY Laptop 64 Bit,64 gigs RAM.Intel i9 chip.Windows 11 Pro and Ultimate. 4 x 2 Terrabyte Hard Drives and 2 x 2 Terrabyte external USB Hard drives. All Posers from 4 to Poser 2010 and 2012, 2014. Poser 11 and 12, 13, Hexagon 2.5 64 Bit, Carrara 8.5 Pro 64 bit, Adobe Photoshop CS4 Creative Production Suite. Adobe Photoshop CC 2024, Vue 10 and 10.5 Infinite Vue 11 14.5 Infinite plus Vue 15 and 16 Infinite, Vue 2023 and 2024, Plant Catologue, DAZ Studio 4.23, iClone 7 with 3DXchange and Character Creator 3, Nikon D3 Camera with several lenses.  Nikon Z 6 ii and Z5. 180-600mm lens, 24-70 mm lens with adapter.Just added 2x 2 Terrabyte portable hard drives.
hornet3d ( ) posted Fri, 05 January 2024 at 3:24 PM
I think Renderosity may have such a tutorial but there are also a wide selection of Superfly presets in Poser that you can experiment with.
randym77 ( ) posted Sat, 06 January 2024 at 2:09 AM
The presets are different in different versions of Poser, I think. I wish they were clearer. With Firefly, it's simple. You can just use the slider if you don't want to mess with too many settings. I usually push all the way over to the left until I'm ready to do a final render.
Superfly is so slow in comparison, and you really need to preview, because often, it doesn't look remotely the same once rendered. Somebody make a preset that's a superfast draft mode.
hornet3d ( ) posted Sat, 06 January 2024 at 5:42 AM
For a quick draft you could use the CPU/GPU Timed 10 second or the CPU/GPU fast preset with the Progressive Refinement ticked.  With the fast you can stop as soon as you have enough samples to meet your needs, both will give a grainy image but does give and insight into whole scene.
Rhia474 ( ) posted Sat, 06 January 2024 at 10:46 AM
Without knowing which version of Poser you're using, it's hard to give good advice, but there are  tuorials here and on posersoftware dot com that could get you started:
https://www.posersoftware.com/article/584/poser-13-introduction-to-lighting-and-rendering-with-superfly
this is for P13
https://www.posersoftware.com/article/516/poser-12-basics-how-to-control-the-quality-of-your-superfly-renders
this is for Poser 12
https://www.renderosity.com/premium-tutorials/163/poser-pro-11-tutorial-rendering-part-1
https://www.renderosity.com/premium-tutorials/164/poser-pro-11-tutorial-rendering-part-2
these are for poser 11
And, finally, the Poser Manual is rather useful in this regard. Poser 13's Superfly render section start on page  536:
https://www.posersoftware.com/documentation/13/Poser_Documentation.pdf
randym77 ( ) posted Sat, 06 January 2024 at 10:50 AM
hornet3d posted at 5:42 AM Sat, 6 January 2024 - #4480123
Hey, thanks. Looks like the 10 second preset is new to Poser 13. It wasn't in Poser 12 or 11.
10 seconds is enough...
Y-Phil ( ) posted Sat, 06 January 2024 at 11:14 AM
There is a node that turns a character into coal as render time, and it's called Ambient Occlusion. that's used for Firefly, and it's not supported by Superfly.
Another reason could the presence of invalid interconnection  between some nodes, shown as dotted lines in the material room. If you open Poser's LOG window, you may find a list of those invalid connections.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
RedPhantom ( ) posted Sat, 06 January 2024 at 11:17 AM · edited Sat, 06 January 2024 at 11:17 AM
Site Admin
Timed renders is new to poser 13. It's also new to Blender where it came from (at least newer than poser 12. I don't remember which version added it.)
And 10 seconds is enough...for a rough draft, as hornet said. It's enough for me to see you need to update your figures shaders if you want it to work in superfly and you are using a very simple lighting setup (that's fine, it's just an observation not a criticism.)
With this, I can see my shaders are good, my lighting is satisfactory, nothing is floating, there is no poke through that I missed, the cap is really off that one bottle where I used a transparency.
That's with cpu rendering. With gpu rendering, it's a little better but no final image
I could use the fx and a denoiser but it might be a little harsh
randym77 ( ) posted Sat, 06 January 2024 at 12:25 PM
The lighting is the default Poser lighting. I usually use an even simpler lighting setup for a final render.
EZSkin would fix it, though I probably won't bother, since I prefer Firefly. I just thought it was an amusing example of things that don't look the same in preview as they do after rendering.
arrow1 ( ) posted Sat, 06 January 2024 at 3:05 PM
I use Poser 11,12 and 13. Cheers
