Forum Moderators: RedPhantom, Staff
New Poser Users Help F.A.Q (Last Updated: 2024 Jun 30 4:54 pm)
Your best bet is to save the camera settings back to the Poser Library for this particular prop. There are many scenes on the market with multiple camera angles already included. You always have the option to create your own or add cameras to the existing scene. All you need to do is load your scene and select the camera angle under the Cameras tab. AFAIK, you can't save camera angles as part of a prop.
You can also save or export the scene as a.PZ3 file which will retain camera angles and everything else you add to the stage.
According to the documentation Readme, there is only one camera in the runtime folder. However, if you are inclined, you can manually build each shop individually with the props under the Props category. It is tedious but you can configure it and populate it your way. For the most part, much of the major set will not be seen in one render anyway.
I opened prop themall, huge, I got it positioned... so it shows most of what promo pic looks like, I want it to stay that way so if I open the prop again I want it the same each time, can then vary it as I please???
how can I do this? Manual doesn't really help...
here you see on left what I've got it to, but I want it to look like promo shot on right. once I get it there, I want that to be prop that opens each time...
don
