Forum Moderators: Kalypso, JacquelineJ
(Last Updated: 2024 Jun 30 4:15 am)
If the shorts are a figure and they fit an unmorphed copy of LF2, then use the copy morphs from the morphed version of LF2.
No, you can't. And you're right, the LF1 to Lf2 is a prop. It won't help with figures.
The fitting helper props are meant to be used on a conforming clothing's obj, for you to import it, copy the morph from the tool, then export the morphed shape as an obj to bring it into the setup or fitting room to make a new conforming figure. LF and LF2's rigs are much too different for a fit to be just a morph in the final figure.
Feel free to call me Ohki!
well I loaded them perfectly onto the lf1 to lf2 white figger, but then I deleted whitey and loaded on my lf2 figger and the shorts didn't fit her?
what should I do in that case?
drawn
