Sun, Dec 22, 2:54 AM CST
Renderosity Forums / La Femme 2
Welcome to the La Femme 2 Forum
Forum Moderators: Kalypso, JacquelineJ
(Last Updated: 2024 Dec 20 9:18 am)
Subject: bought clothing for l'femme 2...BUT
  • 1
  • 2
drawn ( ) posted Sun, 17 March 2024 at 5:38 PM
well I loaded them perfectly onto the lf1 to lf2 white figger, but then I deleted whitey and loaded on my lf2 figger and the shorts didn't fit her?
what should I do in that case?
drawn
RedPhantom ( ) posted Sun, 17 March 2024 at 6:20 PM
Site Admin
If the shorts are a figure and they fit an unmorphed copy of LF2, then use the copy morphs from the morphed version of LF2.
hborre ( ) posted Sun, 17 March 2024 at 6:49 PM
The only problem is that the white figure he refers to is an LF1 to LF2 Prefit prop, and you cannot transfer morphs between the prefitter prop and the shorts figure.
RedPhantom ( ) posted Sun, 17 March 2024 at 9:14 PM
Site Admin
No, you can't. And you're right, the LF1 to Lf2 is a prop. It won't help with figures.
Afrodite-Ohki ( ) posted Mon, 18 March 2024 at 7:00 PM
The fitting helper props are meant to be used on a conforming clothing's obj, for you to import it, copy the morph from the tool, then export the morphed shape as an obj to bring it into the setup or fitting room to make a new conforming figure. LF and LF2's rigs are much too different for a fit to be just a morph in the final figure.
Feel free to call me Ohki!
  • 1
  • 2
