Tue, Nov 19, 10:31 AM CST
Subject: PBR materials
operaguy ( ) posted Sun, 31 March 2024 at 4:48 AM · edited Tue, 19 November 2024 at 10:23 AM
cgaxis is having a major sale on texture packages ...
Does Poser support PBR materials?
I am on Poser 11, contemplating upgrade.
hborre ( ) posted Sun, 31 March 2024 at 5:28 AM
You'll need to assemble the maps into the appropriate materials shaders, but yes, Poser does support PBR Materials.
Afrodite-Ohki ( ) posted Sun, 31 March 2024 at 8:34 AM
Yes and quite easily. In the material room, replace the PoserSurface node for a PhysicalSurface node. All the pluggable sections will be there.
You'll want Roughness type PBR materials, with OpenGL normal maps.
Feel free to call me Ohki!
operaguy ( ) posted Sun, 31 March 2024 at 8:54 AM
Thanks Ohki and hborre,
Hope it's okay to link to it ...
https://cgaxis.com/bundle-2300-pbr-textures-bundle-nw24-03/
Apparently, this is hundreds of dollars of materials on sale as a bundle for $49
the sale has 32 more hours to go.
::::: Opera :::::
hborre ( ) posted Sun, 31 March 2024 at 9:08 AM
There are many other sites that also offer PBR materials for free.
Afrodite-Ohki ( ) posted Mon, 01 April 2024 at 5:26 PM
Forgot to mention:
-If you're using Firefly, PhysicalSurface's Subsurface Scattering and Metallic won't work correctly. In that case, you should use a PoserSurface and nodework to plug the maps.
-If you're using Superfly, displacement will not work correctly unless you subdivide the figure/object a huge lot of times.
Limitations of Poser, sadly.
