Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 01 3:49 pm)
Yes and quite easily. In the material room, replace the PoserSurface node for a PhysicalSurface node. All the pluggable sections will be there.
You'll want Roughness type PBR materials, with OpenGL normal maps.
Feel free to call me Ohki!
Thanks Ohki and hborre,
Hope it's okay to link to it ...
https://cgaxis.com/bundle-2300-pbr-textures-bundle-nw24-03/
Apparently, this is hundreds of dollars of materials on sale as a bundle for $49
the sale has 32 more hours to go.
::::: Opera :::::
Forgot to mention:
-If you're using Firefly, PhysicalSurface's Subsurface Scattering and Metallic won't work correctly. In that case, you should use a PoserSurface and nodework to plug the maps.
-If you're using Superfly, displacement will not work correctly unless you subdivide the figure/object a huge lot of times.
Limitations of Poser, sadly.
cgaxis is having a major sale on texture packages ...
Does Poser support PBR materials?
I am on Poser 11, contemplating upgrade.
