Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2024 Jul 27 12:14 pm)
Post the animation les see how it turns out even with the fault !
How are you exporting the animation? Just interested in your subject and happy to chat about animation. https://youtu.be/grDfmBLCmQc?si=e6sAHNUnR92uqYxx
In the process of saving the pose there should be a window with tick boxes for Morph channels and Body transforms - to save scaling you must tick the Save Body Transformations.
The New HD Toaster from Wamco toasts bread more evenly and acurately than Standard Toasters. Take advantage of the FULL resolution of your bread and try one today, because if your toast isn't in High Definition, you are not getting the most of your toast!
I created an animated figure in which the only thing I changed was the Z Scale on parts of the figure to make them move. When I save the pose everything saves except the Z Scale change. I am running Poser 11 Pro. Am I trying to do the impossible?
