Forum Moderators: RedPhantom, Staff
New Poser Users Help F.A.Q (Last Updated: 2024 Jun 29 9:30 am)
There should be a shader in the materials called add !! Add Beard that will give L'homme the beard.
Guiding you on darkening the skin texture without a Material Room screenshot is challenging. The outcome may look unnatural, depending on the base texture. Additionally, the render engine you're using for the final image is unknown.
If you lost an earlier morph after applying a character texture, it means the character texture you applied included a morph.
I agree with hborre to change a shader we need to see a screenshot of the material room. Something like this is not helpful because everything is piled on top of each other.
something along this line is better.
Then we can see everything and where it is plugged in. Yours might not be as complicated as this one. I purposely did one with lots of nodes for emphasis. But you should get the idea. And make sure you are showing the correct material, shown underlined here.
And we need to know which render engine you are using Superfly or Firefly because there are different ways to do things with the different render engines.
well, I fell prey to another product description that is written for pros and not newbies. Ryker looked good because he "comes" with a beard, etc. so I turned him into my main character and then wanted to put the beard on his smooth face and it turns out, whoa!. it's a jpg file. I dunno what to do with that. Can I stick it on his head? if so, how, please?
drawn
