Fri, Jan 10, 5:54 PM CST
Renderosity Forums / Poser 13
Welcome to the Poser 13 Forum
(Last Updated: 2025 Jan 09 3:32 pm)
Subject: Where is it?
mdbruffy ( ) posted Fri, 19 April 2024 at 8:12 PM · edited Fri, 10 January 2025 at 5:43 PM
Okay. I broke down and bought Poser 13. Now would someone please tell me where the ^*% content folder for the Runtime is? I''ve checked the Program files,I've also looked in Documents. Nothing. Seems like every time I get a new version of this thing, they move it.
Sunfire ( ) posted Fri, 19 April 2024 at 8:41 PM
Online Now!
In the program you will find a purchases tab with the library. Click on it, then click on included and download from there. It will install into a directory called included. It is also where you will find the default content that installs with Poser 13.
Sunfire's Creations
mdbruffy ( ) posted Fri, 19 April 2024 at 8:53 PM
Sunfire posted at 8:41 PM Fri, 19 April 2024 - #4483821
I'm looking at Local Disc  (c:). Program Files > Poser Software > Poser 13 > I do not see a purchases tab. I see a Runtime folder, then a libraries folder, but the only thing in that is an empty collections folder.
RedPhantom ( ) posted Sat, 20 April 2024 at 7:42 AM · edited Sat, 20 April 2024 at 7:44 AM
Site Admin
When you installed Poser, it asked where you wanted the runtime. If you used the default, it would be in your documents folder. Otherwise, it will be where you told it to be.
In the content folder, you will find 4 folders, Downloads, Included, Purchases, and Runtime. Downloads is the default location if you use install from zip to add content. Included is where Poser will put the content that comes with Poser if you use the library to install it. Purchases is where things you buy at Renderosity or Posersoftware. Runtme is Your main runtime. The other three folders also contain runtimes.
ShaneNewville ( ) posted Sat, 20 April 2024 at 8:27 AM · edited Sat, 20 April 2024 at 8:34 AM
mdbruffy posted at 8:53 PM Fri, 19 April 2024 - #4483823
If you're ever curious where things exist, in the Lirbary enable the Extended Details Panel (found at the bottom of library if you click the 3 dots).  it will show you the filepath and it even provides a button for "Show in Explorer" to make it easier to go to.  As far as I've seen it works the same for both official and custom runtime locations,
As for the Purchase tab, that is found within the Library IN Poser.  Not Program Folders.    Open the library in Poser and look at the top of it. You will find the normal "Library" tab as well as a Search, Favorites and Purchases tab.
On the Purchases tab is where you install/download the purchased content.  THEN you should be able to find it in the actual runtime locations once it lives on your harddrive.
I hope this info is helpful to you.
_____________________________
My most recent Poser animation:
Previs Dummies 2
mdbruffy ( ) posted Sat, 20 April 2024 at 8:35 AM
ShaneNewville posted at 8:27 AM Sat, 20 April 2024 - #4483832
If you're ever curious where things exist, in the Lirbary enable the Extended Details Panel (found at the bottom of library if you click the 3 dots).  it will show you the filepath and it even provides a button for "Show in Explorer" to make it easier to go to.  As far as I've seen it works the same for both official and custom runtime locations, so hopefully that will answer your question and be useful in the future.
Found it. Thank you.
Afrodite-Ohki ( ) posted Sat, 20 April 2024 at 4:05 PM
You can also right-click any Library folder and click "Show in Explorer", if you're on Windows.
Feel free to call me Ohki!
mdbruffy ( ) posted Sat, 20 April 2024 at 4:56 PM
Afrodite-Ohki posted at 4:05 PM Sat, 20 April 2024 - #4483860
Okay. I'll try to remember all of this for next time. Thanks.
