Sun, Nov 17, 11:41 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 17 12:50 am)
Subject: Darn DAZ..... DSON help (Poser 10)
Travists ( ) posted Thu, 02 May 2024 at 1:02 AM ยท edited Sat, 16 November 2024 at 1:23 AM
Just bought an item (Super Stinger) and it says it has a DSON importer for Poser, and I've imported other stuff before, but this has no CR2 files with it and for the life of me I can't seem to get it to import.
Any ideas?
FVerbaas ( ) posted Thu, 02 May 2024 at 3:02 AM
Forum Coordinator
Check with vendor.
DSON is/was? an add-on one had to install in Poser to read the obfuscated proprietary file formats DAZ uses. DAZ did not maintain/update it and I do not know if it is still available. AFAIK it did work with Poser10.
hborre ( ) posted Thu, 02 May 2024 at 6:28 AM
Did you also install the DAZ files?ย  Both file types need to be installed and linked to the Poser Library for the DSON Importer to work properly.
hborre ( ) posted Thu, 02 May 2024 at 8:35 AM
After examining the item's webpage, it seems that a PoserCF file for the DSON Importer conversion is not included. One must create the Poser Companion File in DAZ Studio, then place it in a Poser runtime folder, and finally, run the DSON Importer script.
RHaseltine ( ) posted Thu, 02 May 2024 at 9:35 AM
I don't see it saying it has importer files. It says it has "1 DSON Core Installer", which means the native DS files. DSON is the format used by native Daz Studio files (a Daz-Studio specific dialect of JSON), the (no longer available) plug-in was a Poser importer for those files, which required either additonal files to make the product directly accessible through the Poser library or something like Dimension 3D's tool to make it work like a refular File>Import option (I won't post the link as my browser complained there was a trojan on the site, hopefully a false alarm).
Travists ( ) posted Thu, 02 May 2024 at 12:17 PM
FVerbaas posted at 3:02 AM Thu, 2 May 2024 - #4484201
Check with vendor.
Yeah. Installed and still runs when I load the Genesis 2 files. Just can't seem to launch it independently to give the item a shot
Travists ( ) posted Thu, 02 May 2024 at 12:19 PM
hborre posted at 8:35 AM Thu, 2 May 2024 - #4484212
That is a process I'm not familiar with. Exporting to CR2 doesn't seem to work, but then there is no skeleton to choose so I'm guessing it is an assemblage of props. I'm considering seeing about exporting an obj and rebuilding it from that inside Poser.
Travists ( ) posted Thu, 02 May 2024 at 12:21 PM
RHaseltine posted at 9:35 AM Thu, 2 May 2024 - #4484214
Yeah, got the plug in. Apparently it doesn't have the extra file though the artist said it is compatible with it.
Travists ( ) posted Thu, 02 May 2024 at 3:52 PM
Looks like exporting to OBJ would work if the texture files were in the clear.... Don't want to spend on something else useless, Think this would work: https://www.renderosity.com/marketplace/products/88878/xl---content-library-for-poser
RHaseltine ( ) posted Thu, 02 May 2024 at 6:57 PM
Travists posted at 12:21 PM Thu, 2 May 2024 - #4484223
Where did it say that? All I see is the DSON Core, which are the daz Studio files - that does not mean there are Poser companion Files for use with the DSON Importer.
Travists ( ) posted Thu, 02 May 2024 at 7:03 PM
RHaseltine posted at 6:57 PM Thu, 2 May 2024 - #4484245
I was referencing the companion file mentioned by hborre, the product page says it is compatible with the importer for Poser though.
RHaseltine ( ) posted Thu, 02 May 2024 at 7:35 PM
Travists posted at 7:03 PM Thu, 2 May 2024 - #4484246
Ah, I hadn't looked at that section - it is sometimes a bit overoptimistic, I will flag it up.
Travists ( ) posted Thu, 02 May 2024 at 8:10 PM
RHaseltine posted at 7:35 PM Thu, 2 May 2024 - #4484247
Cool. Since you are online (and I don't know if you saw my post on it) do you know if "XL - Content Library for Poser" will successfully pull the jpgs out of the DAZ file? If it will do the whole thing great. I never have the money for the latest version of Poser, so I'm quite familiar with how the file structure sometimes lets new stuff in despite being newer than expected, so I can work with getting a newer file back-ported. And if I can get the jpgs for the textures I can rebuild the thing from the exported then separated OBJ file.
RHaseltine ( ) posted Fri, 03 May 2024 at 3:35 PM
Travists posted at 8:10 PM Thu, 2 May 2024 - #4484248
I don't know, but the textures files for a product will usually be in /Runtime/textues just as they are for Poser content.
Travists ( ) posted Fri, 03 May 2024 at 7:58 PM
RHaseltine posted at 3:35 PM Fri, 3 May 2024 - #4484284
Crud..... just the png thumbnails and *IRAY.duf files. Will keep messing here and there.
Travists ( ) posted Wed, 08 May 2024 at 4:09 PM
Tracked down those darn textures! Assigning them as it asks on import is taking forever, but once done I should be ok.... I hope.
Y-Phil ( ) posted Thu, 09 May 2024 at 7:27 AM
Travists posted at 4:09 PM Wed, 8 May 2024 - #4484520
And don't forget to save your work on the material settings in the library, so that you'll be able to create alternative ones, if needed
๐’ซ๐’ฝ๐“Ž๐“
(ใฃโ—”โ—กโ—”)ใฃ
๐Ÿ‘ฟย Win11 on i9-13900K@5GHz, 64GB, RoG Strix B760F Gamng, Asus Tuf Gaming RTX 4070 OC Edition, 1 TB SSD, 6+4+8TB HD
๐Ÿ‘ฟย Mac Mini M2, Sonoma 14.6.1, 16GB, 500GB SSD
๐Ÿ‘ฟย Nas 10TB
๐Ÿ‘ฟย Poser 13 and soon 14ย โค๏ธ
Travists ( ) posted Thu, 09 May 2024 at 2:26 PM
Y-Phil posted at 7:27 AM Thu, 9 May 2024 - #4484564
Yep! Many of the materials use five textures (six if Poser [10] did normal maps). So I planned on doing just that. Likely go through and build another for the red texture set as well. The OBJ just pointed to the main texture...... Even got the parts moving right!!
