(Last Updated: 2025 Feb 06 11:03 pm)
Things parented tend to match their parents in scale so things like dynamic clothing will still fit on a reduced size figure. You may need to increase the size of the hand accordingly.
Your other option would be to parent the ball to the hand and move that
another option is to use 2 balls. Have one be a control ball. Set it to be invisible in retracing and in camera so it doesn't render. Parent the ball you want to scale and the hand to that control ball.
This solution sounds great,thanks!Just ask,is Poser has a way to reset object's scale to 100% and coordinates to 0,0,0 after I changed it?(like in Maya or 3Dmax)another option is to use 2 balls. Have one be a control ball. Set it to be invisible in retracing and in camera so it doesn't render. Parent the ball you want to scale and the hand to that control ball.
Loopspon posted at 10:59 AM Wed, 8 May 2024 - #4484488
RedPhantom posted at 7:40 AM Wed, 8 May 2024 - #4484477Memorize the object in it's default 0 state and then restore (Ctrl+E), menu is the little right pointing solid white arrow at the top right of the palette...This solution sounds great,thanks!Just ask,is Poser has a way to reset object's scale to 100% and coordinates to 0,0,0 after I changed it?(like in Maya or 3Dmax)another option is to use 2 balls. Have one be a control ball. Set it to be invisible in retracing and in camera so it doesn't render. Parent the ball you want to scale and the hand to that control ball.
I use the"set parent" to make the model's hand move with a ball,when I don't change the scale of them(100%),it goes well.But when I change the ball's size then click the'set parent',the size of the model's hand also changed. I don't want to change the hand's size,what should I do?
