Fri, Feb 7, 3:57 AM CST
Renderosity Forums / Poser 13
Welcome to the Poser 13 Forum
(Last Updated: 2025 Feb 06 11:03 pm)
Subject: IK animation problem,can someone help me?
Loopspon ( ) posted Tue, 07 May 2024 at 8:10 PM · edited Fri, 07 February 2025 at 1:25 AM
I use the"set parent" to make the model's hand move with a ball,when I don't change the scale of them(100%),it goes well.But when I  change the ball's size then click the'set parent',the size of the model's hand also changed.  I don't want to change the hand's size,what should I do?
hborre ( ) posted Tue, 07 May 2024 at 10:39 PM
Did you unparent the ball before resizing it?
Loopspon ( ) posted Wed, 08 May 2024 at 12:03 AM
hborre posted at 10:39 PM Tue, 7 May 2024 - #4484461
Yes.I just build a new ball and drop it to the scene-----I changed its scale---apply IK to the hand-------parent the hand to the ball,then the hand's scale also changed!I dont know why!
RedPhantom ( ) posted Wed, 08 May 2024 at 7:37 AM
Site Admin
Things parented tend to match their parents in scale so things like dynamic clothing will still fit on a reduced size figure. You may need to increase the size of the hand accordingly.
Your other option would be to parent the ball to the hand and move that
RedPhantom ( ) posted Wed, 08 May 2024 at 7:40 AM
Site Admin
another option is to use 2 balls. Have one be a control ball. Set it to be invisible in retracing and in camera so it doesn't render. Parent the ball you want to scale and the hand to that control ball.
Loopspon ( ) posted Wed, 08 May 2024 at 10:59 AM
RedPhantom posted at 7:40 AM Wed, 8 May 2024 - #4484477
This solution sounds great,thanks!Just ask,is Poser has a way to reset object's scale to 100% and coordinates to 0,0,0 after I changed it?(like in Maya or 3Dmax)
primorge ( ) posted Wed, 08 May 2024 at 4:24 PM · edited Wed, 08 May 2024 at 4:30 PM
Loopspon posted at 10:59 AM Wed, 8 May 2024 - #4484488
Memorize the object in it's default 0 state and then restore (Ctrl+E), menu is the little right pointing solid white arrow at the top right of the palette...
