(Last Updated: 2024 Sep 07 12:35 pm)
"It shows the render as it works but when finished it is blank."
This rings a bell for me... In a previous version I had a similar problem with SuperFly, turned out the contrast in PostFX was set to -1 somehow(I didnt do it). Try unchecking 'apply post effects to render' and see if it makes a difference...
I have no idea why Firefly isn't working, but I suspect there may be a cross-bleed of settings that shouldn't happen... I've had renders in SuperFly that showed red splotches(like those that appear when calculating indirect light in Firefly) or incorrect Gama that seem to have been alleviated by turning off or adjusting settings in Firefly. Strange things sometimes surface in the unlikeliest circumstances, I think those are commonly referred to as 'bugs'.
Hope you find a solution...
Y'all have a great day.
0Tried that, stilldoing t.
It shows it rejdering in the screen window bit when finished it just goes empty or blank.
It renders in the queue manager or the little iray preview.
Don't know why iy started doing that.
I've even uninsalled, rebotted and re-installed but getthe same reults.
can you post your render settings?
Are you by chance trying to get a camera angle Looking UP at your subject?
This happened to me all of a sudden, it took me bit then I realized I had the camera BELOW ground.
Working in the work space all looked just fine, but renders came out a Blank Screen.
At first I could not believe this was the case but I moved the camera Up and re-rendered and *POOF* there was my scene....just not at the angle I was wanting so I had to play around until I got an angle Poser would accept and I would accept:
This sounds like you had the camera underground. A workaround would be to make the ground invisible to the cameraAre you by chance trying to get a camera angle Looking UP at your subject?
Poser's camera are sometimes so difficult to retrieve, especially if the scene has many objects.
Here's a trick I use when I have difficulties to retrieve it, often because of the presence of an object that could turn the rendered picture black.
It's all summed up in this image:
- make the aux camera the active one
- turn on the display of the cameras (hierarchy window), and make the main camera visible, this will select it as well
- menu: display > object > cartoon
- if you still don't see it: frame the said cam
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Win11 on i9-13900K@5GHz, 64GB, RoG Strix B760F Gamng, Asus Tuf Gaming RTX 4070 OC Edition, 1 TB SSD, 6+4+8TB HD
👿 Mac Mini M2, 16GB, 500GB SSD
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
RedPhantom posted at 10:03 PM Sun, 12 May 2024 - #4484704
igohigh posted at 9:05 PM Sun, 12 May 2024 - #4484702Yes, I found my camera Was underground.....While I did have the Ground Prop invisible and no shadows I did not think to make ground Invisible to the Camera!This sounds like you had the camera underground. A workaround would be to make the ground invisible to the cameraAre you by chance trying to get a camera angle Looking UP at your subject?
I will certainly give that one a try next time; THANKS!
But I guess this was not Faery_Light's issue???? Just thought I would toss it out...
I"m not sure Faery_Light's problem. She may need to contact support
My Poser was working fine bu sddenly is began rendering a bank screen.
If I renderin the Raytrace window, it renders fine.
it renders f I send t to Queue but not on the main render window.
This happens for superfly andfirefly.
Now all my versions of Poser dors the same.
Can anyone help?
Thank you.
