Sat, Feb 1, 7:25 PM CST
Renderosity Forums / New Poser Users Help
Welcome to the New Poser Users Help Forum
New Poser Users Help F.A.Q (Last Updated: 2025 Feb 01 1:53 am)
Subject: why, when I've parented stage to steps?
drawn ( ) posted Tue, 14 May 2024 at 3:07 PM · edited Sat, 01 February 2025 at 7:22 PM
...does it slip away when I move camera around set?
freekin wearisome this kind of crapola...
drawn
hborre ( ) posted Tue, 14 May 2024 at 4:02 PM
Online Now!
Did you accidentally parent the stairs to the camera?  Select the stairs and on the Parameter/Properties panel, click on the Properties tab and then the 'Set Parents" button.  At the top of the new window, check the Parent status of the object.  If it doesn't indicate that the current parent is 'UNIVERSE', select 'UNIVERSE" in the menu and click 'OK'.
drawn ( ) posted Tue, 14 May 2024 at 6:34 PM
sb, I followed your instructions to the T, but after parenting the stairs to Universe, when I revolved the wheel to change view of camera, it still left the stairs not connected. I must have missed something? is everything else parented by the universe?
hborre ( ) posted Tue, 14 May 2024 at 8:30 PM
Online Now!
Which camera is causing the problem?
drawn ( ) posted Fri, 17 May 2024 at 11:47 AM
revolving the set, with rotation ball...
drawn ( ) posted Fri, 17 May 2024 at 11:48 AM
I changed parent from the stage to universe...?
hborre ( ) posted Fri, 17 May 2024 at 12:11 PM
Online Now!
The rotation ball only revolves the camera, not the stage.
drawn ( ) posted Fri, 17 May 2024 at 3:44 PM
note please: I solved this issue by reloading the set and lo, the steps are locked in right position.
yay!
