Fri, Jan 10, 9:12 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 1:16 pm)
Subject: Manually installing content in Poser 13
Simbad6 ( ) posted Sat, 18 May 2024 at 10:20 AM · edited Fri, 10 January 2025 at 6:18 PM
I am new at Poser 13. I would like to install content but I want to install it manually, so that I have things exactly where I want in my library.
I did as I have always done with older versions of Poser : I installed the poses in the Pose folder, and the textures in the Texture folder, but it does not appear in my library, even if I refresh it. I probably missed something, but what ?
hborre ( ) posted Sat, 18 May 2024 at 10:40 AM
In what location are you manually installing?  Windows or MAC?  To the Poser 13 Content runtime?
Simbad6 ( ) posted Sat, 18 May 2024 at 10:46 AM
I'm using Windows and I'd like to install in the Download library, where all my old purchases for PoserPro 2012.
RedPhantom ( ) posted Sat, 18 May 2024 at 10:59 AM
Site Admin Online Now!
I believe Poser 12 and Poser 13 have separate download libraries. You might check that you used the correct downloads runtime and that's also the runtime you're looking at.
hborre ( ) posted Sat, 18 May 2024 at 11:05 AM
Where is the Download Library located?  If you are installing in the Programs Files Primary Poser installation, that is a bad location.  With the current Windows 10 or 11, UAC  will interfere with installed content, either preventing access or relocating them to a virtual location on your drive.  My recommendation is to install in a location away from the Programs Files folder.
Simbad6 ( ) posted Sat, 18 May 2024 at 11:10 AM
RedPhantom posted at 10:59 AM Sat, 18 May 2024 - #4484953
When I installed Poser 13, I chose the "Dowload" library for my old PoserPro 2012 runtime, and i works fine. But it seems that any product I add in this runtime won't appear in the library. Is there a way to check to what runtime the library is attached ?
hborre ( ) posted Sat, 18 May 2024 at 11:16 AM
Is Poser open while installing content?  If so, you need to refresh the Library window.  Make sure that the PoserPro 2012 Download runtime is linked to Poser 13.
Simbad6 ( ) posted Sat, 18 May 2024 at 11:32 AM · edited Sat, 18 May 2024 at 11:34 AM
hborre posted at 11:05 AM Sat, 18 May 2024 - #4484955
Poser 13 is installed on my C: drive, while all the runtimes are installed in the D: drive. It just seems that the library doesn't update.
Am I the only one who installs manually ?
hborre ( ) posted Sat, 18 May 2024 at 11:43 AM
I always install manually because I have numerous runtime folders and separate my content accordingly.  However, I always inspect the folder hierarchy within each zip file so that the primary folder is called runtime.  Otherwise, I correct the hierarchy structure within the zip file and install it afterwards.  I have all my runtime folders on the D: drive.
Simbad6 ( ) posted Sat, 18 May 2024 at 12:03 PM
hborre posted at 11:43 AM Sat, 18 May 2024 - #4484964
I suppose you have had previous versions of Poser. Do you have a special library for older stuffs ? Do you use the default "Download" library or have you created new libraries ? Perhaps I should put all my old purchases in a new library rather than using "Download", which was pre-installed ? Although I don't see any reason why this one wouldn't be appropriate...
Simbad6 ( ) posted Sat, 18 May 2024 at 12:07 PM
I tried to create a new library for the same runtime and, this time, I find the new product I have installed.
freek2 ( ) posted Sun, 02 June 2024 at 5:39 PM
I may be speaking out of turn, but working with megatons of disparate media in the TV industry [stills/audio/video], I found that media sitting on the desktop provides the easiest, fastest, and most stable access to said media. Transferring this ideology to Poser 13, I just create a Runtime folder there for all of my content. It looks a little weird in the Poser's GUI library, but works really well [this concept should work equally well in PC or Mac].
