Wed, Jan 8, 7:11 AM CST
Renderosity Forums / Poser 13
Welcome to the Poser 13 Forum
(Last Updated: 2025 Jan 08 6:33 am)
Subject: Sahdow color
mini70 ( ) posted Sat, 18 May 2024 at 8:23 AM · edited Tue, 07 January 2025 at 12:17 AM
The color of the shadow is too dark. What can I do to get a light shadow?
RedPhantom ( ) posted Sat, 18 May 2024 at 8:25 AM
Site Admin Online Now!
What kind of lights are you using?
hborre ( ) posted Sat, 18 May 2024 at 8:40 AM
Under the Parameters tab in the Parameters panel for the light there is a 'Shadow' dial.  By default, that value is set to 1.000 (100%).  Shadow values should never be set to 1.  Try reducing that value until you achieve a more realistic render.
mini70 ( ) posted Sat, 18 May 2024 at 8:59 AM
RedPhantom posted at 8:25 AM Sat, 18 May 2024 - #4484938
I only used one sunlight(infinite).
mini70 ( ) posted Sat, 18 May 2024 at 9:28 AM
hborre posted at 8:40 AM Sat, 18 May 2024 - #4484939
As you can see in povture, the shadow is dark even though the value has been reduced.
hborre ( ) posted Sat, 18 May 2024 at 10:37 AM
To be honest, the Sun intensity value is too high.  If you are using Superfly rendering and relying on HDRI illumination as well as an infinite light, I would reduce the sun intensity value.  Whenever I create an outdoor scene with a combination of HDRI and physical lights, the intensity value of the lights are decreased tremendously.  I have used values of 50% or lower, depending on how much of an influence I want the HDRI to impact the scene.
Y-Phil ( ) posted Sat, 18 May 2024 at 11:14 AM · edited Sat, 18 May 2024 at 11:16 AM
Using Poser 13's default "Mondello Beach", you  don't need any light- The default scene has one default light that has no effect on the render, as the scene is lit by the HDRi picture.
Example:
The said preview light has its Diffuse and Specular values set to black:
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
mini70 ( ) posted Sat, 18 May 2024 at 11:43 AM · edited Sat, 18 May 2024 at 11:43 AM
hborre posted at 10:37 AM Sat, 18 May 2024 - #4484949
I tried to reduce the intensity of the sun. But this time, the skin became too dark and the color of the shadow didn't change.
RedPhantom ( ) posted Sat, 18 May 2024 at 12:13 PM
That shouldn't be. The HDRI should give plenty of light to the scene. Are there any other things in the scene that we can't see that might be affecting the light?
Can you show us screenshots of the shaders for the light and the background?
hborre ( ) posted Sat, 18 May 2024 at 12:42 PM
I quickly set up a similar scene to determine what is happening with the renders.  My first observation is that the shaders on the figure and clothing are not optimized for Superfly and are responding to the 'Sun' light source.  That is why the figure darkens as the light intensity value is decreased.  My second observation is that the shadow on the shadow-catching ground plane is responding to HDRI illumination, not the 'Sun' light source.  That explains why varying the 'sun' intensity has no effect on the shadow density.
Check if the 'sun' light source has Shadows unchecked in the Properties Tab.  My suspicion is that it is unchecked, otherwise, you should have 2 shadows on the ground plane.  The solution to lighten the shadow is to place a low intensity, non-shadow area light or spotlight pointing toward the shadow behind the figure.  This is a hack but it will make the render more acceptable.
mini70 ( ) posted Sun, 19 May 2024 at 4:45 AM · edited Sun, 19 May 2024 at 4:46 AM
Y-Phil posted at 11:14 AM Sat, 18 May 2024 - #4484957
Example:
Thank you very much. Finally i can get shadow color what I want.
mini70 ( ) posted Sun, 19 May 2024 at 4:48 AM
RedPhantom posted at 12:13 PM Sat, 18 May 2024 - #4484970
Here are the screenshots of the shaders for the light and the background.
mini70 ( ) posted Sun, 19 May 2024 at 5:06 AM · edited Sun, 19 May 2024 at 5:06 AM
hborre posted at 12:42 PM Sat, 18 May 2024 - #4484972
Thank you very much for your help!
You are right. The clothing are not optimized for Superfly because I just used a base color map.
hborre ( ) posted Sun, 19 May 2024 at 5:43 AM
I noticed a gray color chip on the Light material room node (Sun), change that to white.  That might be the cause of gray effect when you turn down the intensity of the illumination.  Turn off Shadows on that same light, decrease the intensity, and render your scene.  You should see some improvement in the skin texture with your render.  We'll address using the PhysicalSurface root node later.  I will be away from my computer most of the day until this evening.
mini70 ( ) posted Sun, 19 May 2024 at 6:38 AM
hborre posted at 5:43 AM Sun, 19 May 2024 - #4485002
Than you so much!
mini70 ( ) posted Sun, 19 May 2024 at 6:40 AM · edited Sun, 19 May 2024 at 6:40 AM
Example:
This is my last result.
mini70 ( ) posted Tue, 21 May 2024 at 11:30 PM · edited Tue, 21 May 2024 at 11:31 PM
@ Y-Phil
I'm so curious that I'm asking you.
How did you manage to lighten the shadow on this link(https://www.renderosity.com/forums/threads/2954843/poser-12-renders?page=9)?
I tried Poser's default round ground plane HR like you said, but it didn't work in P13.
I wonder how people can get a light shadow in P13 if they use background node + the round ground plane in shadow catcher without using startup scene.
Y-Phil ( ) posted Wed, 22 May 2024 at 3:59 PM · edited Wed, 22 May 2024 at 3:59 PM
mini70 posted at 11:30 PM Tue, 21 May 2024 - #4485137
I've done a few tests and indeed: at the time of  Poser12, it looks like the shadow seemed influenced by the environment lighting, and it's clearly not the case any more in Poser13.
As a side node, we've been waiting for a true shadow catcher for Superfly since the its beginning. The only other solution is by using Snarly's shadow catcher, but it's not obvious. I've kept a video in which Snarly explains how to use it, among other things.
In the present case, using Poser13 and the round groundplane as shadow catcher: the color of the PoserSurface Node's Diffuse color influences the color of shadows, as well as the other objects' color.
To make the shadows lighter, I see the use of the PoserSurface node's transparency. But use it with caution as the background disappears also. It appears in my scene as I'm not using any 3D ground, other than the shadow catcher.
Here's an example: the same scene, with just the skins and hairs material updated. I'm using Pure White for the shadow catcher's Diffuse color.
Transparency=0:
Transparency=0.2:
But honestly,  don't find it really convincing.
Here I tried to add an infinite light without shadow, vertically, at 10%:
Detailed view to compare:
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
nerd ( ) posted Thu, 23 May 2024 at 9:38 AM
Forum Moderator
Poser uses the HDRI lighting that is part of Cycles. And yes the shadows are not ideal. Being a PBR, Cycles isn't good at non-physical renders. Shadow catchers are definitely not part of this reality.
Y-Phil ( ) posted Thu, 23 May 2024 at 12:50 PM
nerd posted at 9:38 AM Thu, 23 May 2024 - #4485192
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
mini70 ( ) posted Sun, 26 May 2024 at 7:32 AM
Y-Phil posted at 3:59 PM Wed, 22 May 2024 - #4485154
Transparency=0:
Transparency=0.2:
I got it, thank you very much for the detailed explanation.
mini70 ( ) posted Sun, 26 May 2024 at 7:33 AM
Thank you.
Y-Phil ( ) posted Sun, 26 May 2024 at 7:33 AM
mini70 posted at 7:32 AM Sun, 26 May 2024 - #4485306
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
