Vue F.A.Q (Last Updated: 2024 Sep 26 4:27 pm)
Mine also says Poser SDK (11.0.5), like yours. I tried saving a pz3-file outside of the Poser runtime and then the figure showed up as white boxes in the the top, side and front views, but it rendered ok. The same figure pz3-file from inside the Poser runtime behaved correctly.
It seems that the path to your Poser installlation is rather long. Could that be a problem maybe? Just guessing, I don't know at all. I used Vue a little many years ago so I know very little about it. Sorry I can't help you.
I tried with both Vue 2023 and 2024 and it is the same behaviour as far as I can see. So, props import well, but it doesn't work when I try to pose figures in Vue. According to the manual, there is supposed to appear a list of body parts when I double-click a figure. But the box where they should appear is empty.
I am having the same issue on my Mac with getting Vue 2023 to recognize the Poser 11 program. In the screenshot below, you can see the Poser application icon is grayed out. So what the heck do I do? I used to have Vue Infinite years ago; I don't remember which version of Poser back then, but they played well together. Now it seems Vue just doesn't want anything to do with Poser and have the whole playground to itself. Aaaack!
MarianneR posted at 1:00 AM Sat, 11 May 2024 - #4484664
We've got the same difficulty - we had Vue 2016 where Poser figures could be reposed, and the list of body parts did appear. We've just tested our old version of Vue (fortunately hadn't dismounted it!) and it still works and handles Poser figure reposing. But in the new 2023 version of Vue (using the same SDK for Poser 11.3)ย the list of body parts doesn't show up. Any idea what can be done to deal with this? We're using Windows 10 and a reasonably powerful PC - no limitations on the spec showing up.I tried with both Vue 2023 and 2024 and it is the same behaviour as far as I can see. So, props import well, but it doesn't work when I try to pose figures in Vue. According to the manual, there is supposed to appear a list of body parts when I double-click a figure. But the box where they should appear is empty.
mouser posted at 5:51 AM Thu, 16 May 2024 - #4484818
Well, I'm the one who reads and answers all the emails there and I do remember I replied to such a question in the last days, but do not remember if it was exactly your case.That's who I contacted, as its free I'm guessing someone will look eventually.
But do not forget, there are other formats out in this world that both programs can handle too, Try others if pz3 does not work as expected. And do not forget as well that for every import, no matter where it comes from, it is very normal that the materials need adaptation so that the render engine will be able to give an ideal result.
Can you describe a bit more what e-on could have done when the Poser crew did not provide them with a new SDK?
Simply install Poser 11 on the same computer, direct Vue to this and it works. I have it running on Mac and Windows, no problem.
BUT, keep in mind there are other formats as well, no need for pz3 and only pz3.
Last but not least, now it is too late - Bentley does not do any support or development on the software,. If the source code will become open source the future will show, this is dependent on a lot of thing. And to be clear, if that happens then I think pz3 import will be out - I'm sure the SDK is under copyright by the Poser people and I am not sure if they want to give that out for free.
Are you getting an error message, or is something else happening? I pointed it to my copy of Poser 11 and it works fine. At least I assume it's working fine. It loads the file without any error messages.
I click Import Object
The Import Options box appears
I click OK
Message requiring I point to Poser application
I click OK
Poser Import Setup box appears
I locate the Poser 13 folder with the Poser AP in it
I click OK
The box disappears and then instantly reappears and Nothing, the setup box just suits there.
No error message, no clue?
I have been using Poser & Vue since Poser 4 & Vue Desprit without issue until now.
I stopped once Vue moved to a subscription based system.
And yes I tried Poser 11 as well, same result.
mouser posted at 1:12 PM Thu, 9 May 2024 - #2987474
I'm on Windows 11.I have downloaded the free version of Vue 2024 and it is unable to find/open poser 11 when I import a poser file?
Error codeย DLOIS_1791
Has anyone else run into this issue?
Are more up to date versions of poser compatible?
Thanks for any advise.
For fun, I downloaded the trial version of Poser Pro 11.3.818 from posersoftware.com and installed it. However, I get the same error message as you. I don't have a serial number, so I can't test any further. Maybe Posersoftware will contact me about buying a serial number. I assume TRIAL versions of Poser do not work with E-on's Poser SDK.
Just to clarify that - it is not e-ons SDK, it is Bondwares. No SDK from them, no compatibility with later versions. And now it is too late for an update.
DLOIS_1791 is a generic error message that tells only that a generic problem in loading the file has happened. Nothing more.
And indeed, I think the trial version will not do the trick here. But in this I might be wrong.
My guess is still that the problem might come from the fact that the pz3s that someone tries to load that has Poser 11 installed and directed Vue correctly to it but uses later versions of Poser to generate those, contains features that are newer than Poser 11. And/or tries to use import features that are no longer compatible.
For a test I recommend to load an old Poser character without any special settings and use the basic import settings - no re-posing, no Poser shader tree and only frame 0 and not an entire Poser animation. That is interesting to see, if that works or not, here it does.
The PZ3 I used was the default figure when opening Poser Pro 11 TRIAL. No Poser add-ons.
On my old computer, I have VUE 9.5 Infinite with Poser 6. I can import a PZ3 made from Poser 6 into a VUE 9.5 Infinite scene. Save the scene. And them open the scene in VUE 2023. The embedded Poser 6 PZ3 object loads with the scene just fine into VUE 2023. And the scene renders from VUE 2023 look just like the renders from VUE 9.5 Infinite. This all happens without telling VUE 2023 anything about Poser importing.
I don't plan on buying Poser Pro 11 if it's not going to work with VUE 2023.
Just for my understanding, why do you all insist so heavily on pz3 file exchange? Has anybody tried to export from Poser in another format that Vue can read and use this route?
obj works for me as well, Collada too. Both of course need a bit of tweaking of the materials, but that is the same with the pz3 imports into Vue.
Btw, before you mention it, Collada comes in with very strange reflection settings, but that is a problem of the export, not of the Vue import., And in Vue you can very easily correct that with "edit all materials" in one go.
So I don't need to fiddle with every material for every body part. Why do you think I insist so heavily on PZ3 for import?
I need to fiddle with each material as well, when I import pz3 files. The treatment of materials is very different between Poser and Vue. But this is not a big issue really, can be done with "edit all materials" in almost one go, only the eyes need a bit more tweaking, but with macros in Vue this is all very easy to do.
And now that there is no development of Vue anymore, you have to work with what you have. So, when I understand it right, you better do not use Vue when you have to tweak the materials to get the best result?
However it is, I have all said in this thread, I'm out here now.
I'd like to hear from VUE 2023/2024 users here who do have Poser working for their importing. Specifically, which version of Poser for Windows is being used? I see that SkinVue is now included with VUE. Does it work with the Poser used for importing?
This is what I did
Go to file>options click on the import tab
hit the configure Poser import button
Hit browse. Move to where you have Poser installed.
Pick your Poser folder and then hit the Select Folder button.
I ignored the sdk option because there was only one choice.
Now I pointed it to my Poser 11 install. I had it pointed at my Poser 13 install using the same method but I was getting this error message when I tried to import the scene
I would hit no and it would continue on like there was no problem. It just was annoying so I changed the folder.This is a render of a Poser scene. I did a little editing of the skin because it was too shiny. The lips should have been done too. A few other shaders need tweaking. The buttons should be silver. It was just a test render. I don't know much about Vue yet.
I also wonder if the errors have anything to do with the operating system or where Poser is located. As you can see my copy of Poser isn't in the program files. And I'm on Win 10.
Did you get your Poser 11 from Smith Micro? Interesting.
Has anyone had a problem with the Poser 11 from Poser Software (Bondware)?
I had originally gotten it from them, but then I got the Bondware version because Smith Micro shut their server down. And at one point I uninstalled it so there shouldn't be anything left of the Smith Micro version.
So what's the exact version and release number of Poser (Pro or non-Pro) for Windows that works with the free VUE 2023 and VUE 2024?
My Poser 11 Demo expired. So I don't even know what version it was. It won't let me get to the About screen to find out.
