Tue, Jan 21, 7:43 PM CST
Renderosity Forums / La Femme 2
Welcome to the La Femme 2 Forum
Forum Moderators: Kalypso, JacquelineJ
(Last Updated: 2025 Jan 21 2:21 am)
Subject: weird sticky out part of otherwise fitting shorts?
drawn ( ) posted Tue, 11 June 2024 at 5:44 PM · edited Tue, 21 January 2025 at 10:41 AM
LF2 wearing shorts looked good until I noticed this weird thingy flapping out from her thigh...any ideas on getting rid of it?
thanks,
drawn
RedPhantom ( ) posted Tue, 11 June 2024 at 6:49 PM
Site Admin
These were converted from Lafemme weren't they? Did you remember to copy the joint zones?
DeeceyArt ( ) posted Tue, 11 June 2024 at 7:40 PM · edited Tue, 11 June 2024 at 7:41 PM
First things first.
1. Select the shorts in your scene.
2. Choose Menu command Figure > Copy Joint Zones From.
3. A dialog pops up. If the shorts are conformed to La Femme (they should be), the dialog will automatically select La Femme as the figure to copy joint zones from.  If not, use the down arrow to select the La Femme figure from the menu. Accept the default target tesselations, and choose OK.
If that doesn't help the situation, let us know. Because you'll have to edit weight maps if that doesn't do the trick and that will get a little involved.
drawn ( ) posted Wed, 12 June 2024 at 8:47 AM
Yay, it was the copy joints thing, which I had originally forgotten. thanks, team!
drawn
