Forum Moderators: Staff
New Poser Users Help F.A.Q (Last Updated: 2024 Jun 22 8:19 am)
can I "make" new cameras and leave them in the 3 or 4 rooms I'll shoot in?
yeah, I'm concerned about the walls. but I;m learning to navigate my main camera through, kind of.
on the bed I'm using for the boy, it has a pretend bed cover but I can't open it up and slide the kid in. plus I need a good pillow for him which I hope I can find somewhere. can I make a bed cover, give it the Cloth treatment as in one of the tutorials, and drape if over his body? I think so. can I put a pattern on it from somewhere?
asking a lot of info here, thanks for being helpful,
drawn
Top Menu > Object > Create Camera > (probably) Dolly
The new camera will be at the bottom of the Cameras drop-down list.
Dolly cameras behave like a camera mounted on a tripod they will be easier to manage in a confined space.
Important note is that custom cameras are locked to a scene. You can't saved them to the library for use in another scene.
Creating a bed spread or cover will require using the Cloth Room and running an animation to drape the Cloth mesh over the boy and bed. Applying textures isn't a problem, providing that the patterns are scaled properly. After the animation, the draping cloth should be saved to the Library as a prop, otherwise, you will need to rerun the animation every time you reload the scene.can I "make" new cameras and leave them in the 3 or 4 rooms I'll shoot in?
drawn
I believe Mother's House is what I need for 2 projects but I need to get inside and work with it, etc. the outside looks like this at full magnification.
the closest I've been able to get inside with main camera is:
I need to walk through the house, but how do I do it? I shrunk it to 5% and this is what I see, but I cannot figure how to explore at this magnification or minification with main camera, bump into walls, not see rooms from one POV, etc. Any advice?
drawn
