Mon, Jan 20, 7:26 AM CST
Renderosity Forums / Poser 13
Welcome to the Poser 13 Forum
(Last Updated: 2025 Jan 20 5:44 am)
Subject: Poser 13 settings?
randym77 ( ) posted Wed, 12 June 2024 at 12:16 AM · edited Mon, 20 January 2025 at 7:22 AM
My old computer died, and I got a new one. Probably spent more than I should, but I tend to use my computers for a long time.
Years ago, when my old computer and Poser 11 were new, someone explained what settings I should use. I recall it made  big difference. So...what settings should I use?
In particular, how many threads? It's supposedly a i9-14900K processor with 24 cores, 32 threads, 3.2GHz to 5.6GHz. Last time, someone told me it's not a good idea to let Poser use all the threads available.
Graphics card is a GeForce RTX 4090 with 24GB. Render settings give me a choice of Nvidia GeForce, OptiXNividia GeForce, and the CPU. Which one should I pick?
mmitchell_houston ( ) posted Wed, 12 June 2024 at 6:02 AM
I cannot answer all of your questions, but I can say that if you are trying for realistic renders, under Render Settings you select the Nvidia GeForce option. CPU should almost never be selected.
System: Lenovo Legion Pro 7 16IRX9H Laptop | Windows 11 Professional | 32GB RAM |  14th Gen Intel® Core™ i9-14900HX | Nvidia RTX 4090 Laptop GPU 16GB 9728 CUDA Cores
mikemitchellonline.blogspot.com   |   Poser Noir Comics Tutorial   |   Illustrations Honored by Renderosity
RedPhantom ( ) posted Wed, 12 June 2024 at 7:34 AM
Site Admin Online Now!
I'd go with the Optix option. It is so much faster than anything else. And while I'm no expert, I've always been under the impression you want software to use all the threads if needed. Having it use less than that might be for if you want to multitask.
randym77 ( ) posted Wed, 12 June 2024 at 9:52 AM
mmitchell_houston posted at 6:02 AM Wed, 12 June 2024 - #4486076
Thanks! I never used CPU with Poser 11. but I seem to recall people saying CPU is better with some graphics cards.
randym77 ( ) posted Wed, 12 June 2024 at 10:00 AM
RedPhantom posted at 7:34 AM Wed, 12 June 2024 - #4486081
Yes, I think the reason was so you could use your computer for other things while Poser is rendering.
I will give Optix a try. I bought Poser 13 awhile ago, but was still mostly using Poser 11. I had no idea Optix was a thing.
Rhia474 ( ) posted Wed, 12 June 2024 at 10:07 AM
Online Now!
If you have an OptiX option, i highly recommend it on new(er) rigs. The render speed alone in P13 combined with that is a game changer.
RedPhantom ( ) posted Wed, 12 June 2024 at 11:31 AM
randym77 posted at 10:00 AM Wed, 12 June 2024 - #4486099
I don't believe Optix was available in Poser 11. And if you're using the GPU for rendering, you won't be using much CPU power because the GPU is doing the heavy lifting. And using larger buckets will also speed up GPU rendering. I often have mine at 2048 vs 32 for CPU. You'll have to test to see what's the fastest and what your computer can handle for your scenes. Some of my busier scenes, I shrink it some.
Y-Phil ( ) posted Thu, 13 June 2024 at 7:52 AM
If I'm not wrong, any nvidia generation that come after the 20xx series isn't recognized by Poser11. The most powerful nvidia card to be used with Poser11 is the 2080Ti.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
RedPhantom ( ) posted Thu, 13 June 2024 at 11:55 AM
I have a 20xx series and while Poser 11 will render with the GPU, it doesn't have the Optix option and that makes so much difference in speed.
nerd ( ) posted Thu, 13 June 2024 at 7:23 PM
Forum Moderator
Poser 11 only Supports RTX cards in the 20xx series. It doesn't have Optix
Poser 12 supports up to 30xx it has first generation Optix which is a little fast.
Poser 13 supports all current RTX cards and has 2nd generation Optix which is ludicrous fast.
Y-Phil ( ) posted Fri, 14 June 2024 at 6:02 AM
Thank you nerd for the details.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
ChromeStar ( ) posted Fri, 14 June 2024 at 3:52 PM
randym77 posted at 12:16 AM Wed, 12 June 2024 - #2988032
The 4090 works great in the Optix setting. Just for fun I recommend setting up a scene (using Superfly) and rendering it all three ways: CPU, GeForce, and Optix. Compare the times. It's dramatic. But afterwards you'll stick with Optix for sure.
randym77 ( ) posted Thu, 04 July 2024 at 1:33 PM · edited Thu, 04 July 2024 at 1:34 PM
Finally got around to trying a benchmark. I used this one, from the Poser 11 days.
https://www.renderosity.com/freestuff/items/83640/benchmark-test-scene-for-superfly
It took 20 minutes to render the scene in Poser 11, with my old computer. It was just under 14 minutes with Poser 12, also with my old computer.
With my new computer and Poser 13:
15 seconds with Optix
20 seconds with GPU
5 minutes 6 seconds with CPU
