New Poser Users Help F.A.Q (Last Updated: 2025 Jan 21 6:44 am)
Content Advisory! This message contains nudity, profanity, violence
sorry forgot to push nudity button because I cannot fit Ben in pjs or underwear (for l'homme) or Will, and the purpose of bedcover is to cover him, but it floats away too. please forgive, dammit, or I'll beat my fists on the wall!
drawn
yeah, the bed is all wompy jawed. Select the bed. Then go to edit>restore>object and it should fix it for you.
It appears that the cameras also need to be reset to their default settings. There is so much chaos going on in the scene, props and figures are in disarray. I suggest zeroing everything and starting over again. Your workflow should start with the Ground Plane. Next, introduce the bed and add and parent the pillows to the bed. Load the Ben figure, pose him, and translate him onto the bed. It makes no sense to dress the figure if it is going to be undercover in the final render. For forum presentation purposes, dress him with the appropriate clothing from the Library; delete it before doing the sheet simulation.
Parent the bed to the figure so they don't become separated from each other when moving either prop or figure. Once all the world translations are determined and set, position the sheet for cloth simulation and run the animation. You want to simply the workflow, but make it efficient enough to avoid unfortunate issues. Save often so that you can go back to a restore point rather than reconstructing the scene from scratch.
my view of the main props and actor has gotten disrupted and I need to restore it. this 3-port view shows the problem, I think. the bed is floating at an odd angle to the ground in the aux and top views but the Main view I have no comprehension where anything is. the bed and Ben are floating in outer space and I cannot find Ground can someone please guide me step by step??
drawn
