Wed, Jan 15, 10:51 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2025 Jan 15 2:29 am)
Carrara Free Stuff here.
Subject: Spline or Vertex
benney ( ) posted Tue, 30 July 2024 at 7:44 AM · edited Wed, 15 January 2025 at 10:48 AM
I know this may sound like a daft question, but if i want to create a simple model that can be created in either the Spline or vertex modeler. Which one of these would use the less CPU. The reason I ask is because I am creating a complex scene and need to keep the CPU usage down as low as I can. Any help on this would be greatly appreciated.
headwax. ( ) posted Tue, 30 July 2024 at 5:45 PM
Guessing spline. Maybe experiment. Model an example in spline, then copy and paste it ( not duplicate it) and convert one instance to mesh. Then compare the two sizes eg when you save them. That might shed some light, maybe not. Doesn't take into account eg uv texturing etc.
WendyLuvsCatz ( ) posted Thu, 01 August 2024 at 10:02 PM
sort of depends, spline is actually worse using the Octane render plugin as it converts it to triangulated mesh anyway and is often massive as very smoothed
not to mention you need to use a suitable UVW projection function to texture it
most people are not using Octane though to be fair
Dreaming Kitty Channel
Tom R. Toe
My ArtyFarty AI channel
benney ( ) posted Fri, 02 August 2024 at 5:26 AM
I did try the earlier suggestion of converting it into a vertex model and then I checked out the result. A massive YUK! It had turned it into nothing but a triangulated mash of which there was no way I would model like that "I always use quads in my modeling" and so I knew the vertex model would show as a larger model than the spline. As far as rendering goes, have never heard of the "Octane plugin".. what is it and where do i get it from?
WendyLuvsCatz ( ) posted Fri, 02 August 2024 at 3:21 PM
Otoy but it's subscription only now
I bought it almost a decade ago, you need a Nvidia card and not sure what's supported now, I know my older version OR4 will not support cards much later than my 2080Ti
Tom R. Toe
