(Last Updated: 2024 Sep 28 12:06 pm)
I've never done much with the shortcuts so I can't say much. The only thing I can think of where this happens when you restart is what are your launch behavior settings. I'm assuming you don't have it set to factory default but if you have it as the preferred state, did you remember to save the preferred state after you set all your shortcuts?
Could it be a problem with the German interface? Did you asked the support?
๐ซ๐ฝ๐๐
(ใฃโโกโ)ใฃ
๐ฟย Win11 on i9-13900K@5GHz, 64GB, RoG Strix B760F Gamng, Asus Tuf Gaming RTX 4070 OC Edition, 1 TB SSD, 6+4+8TB HD
๐ฟย Mac Mini M2, Sonoma 14.6.1, 16GB, 500GB SSD
๐ฟย Nas 10TB
๐ฟย Poser 13 and soon 14ย โค๏ธ
Yes, I have tried this: Launch Behavior is set to "Launch to preferred scene". I have then edited my shortcuts, closed the shortcut editor and pressed "Set preferred scene". The preferred scene loads, yet Poser continues to reset the shortcuts.The only thing I can think of where this happens when you restart is what are your launch behavior settings. I'm assuming you don't have it set to factory default but if you have it as the preferred state, did you remember to save the preferred state after you set all your shortcuts?
Y-Phil posted at 11:01 AM Fri, 16 August 2024 - #4488424
Perhaps I should have made this clearer: I'm not using the German interface, Poser is running in English.Could it be a problem with the German interface? Did you asked the support?
Also, I figured I'd ask here first to find out whether this is a common issue. Will try support next.
Is there any synchronizing software, running in the background, that could be desperately restoring the said file?
๐ซ๐ฝ๐๐
(ใฃโโกโ)ใฃ
๐ฟย Nas 10TB
Y-Phil posted at 1:55 PM Sat, 17 August 2024 - #4488479
No, there isn't. And yes, I did check :)Is there any synchronizing software, running in the background, that could be desperately restoring the said file?
And I did contact the official support. Turns out it is a known problem of the current Poser build.
I've tried to prevent Poser from overwriting the Accelerators.xml file by setting the write-protect attribute. This worked ... to a point. Poser 13 is no longer overwriting the Accelerators.xml file, but it still ignores the settings therein. When I find the time, I will try out the poser.xrc route.
Soo a new release of Poser 13, let's hope that it'll be managed.
๐ซ๐ฝ๐๐
(ใฃโโกโ)ใฃ
๐ฟย Nas 10TB
In short: Poser 13.3.686 keeps resetting my custom shortcuts. Is this a known bug or just me?
- I changed the shortcut to the Dolly Camera. This works.
- I changed the shortcut to the LHand and RHand cameras. These reset after Poser is relaunched.
- I cleared the "memorize object/figure/lights/camera/all" shortcuts. These reset to the default shortcuts after Poser is relaunched.
The actual situation is even a bit weirder:
- I set my shortcuts and they work.
- I shut down and relaunch Poser: My custom shortcuts are gone.
- I shut down and relaunch Poser again: The default shortcuts are back.
My Windows 10 install is working with a German keyboard layout.
In %Appdata%\Roaming, I oddly have two Poser subfolders, "13" and "13_2024_03_13 10_45_57 PM". Both contain a "Accelerators.xml" file.
I tried the following:
- Checked for conflicts.
- Rename the "Accelerators.xml" files to reset my customizations. I then changed my keyboard shortcuts again. The same problem persists.
(I should possibly mention that Poser also resets shortcuts pointing to German-language-specifics keys, such as Ctrl+ร or Ctrl+ร.)
I am considering the following workarounds:
- Set my custom accelerators and set the read-only attribute for "Accelerators.xml" to prevent Poser 13 from resetting them.
- Go back to the old ways and edit the "Poser.xrc" file in the \Runtime\ui\ subfolder of the Poser installation directory.
Could anybody perhaps suggest a less brutal way to solve my problem?
