Sat, Feb 1, 8:55 AM CST
Renderosity Forums / Suggestion Box
Welcome to the Suggestion Box Forum
Forum Moderators: msansing
Suggestion Box F.A.Q (Last Updated: 2025 Jan 24 1:15 pm)
This forum is designed for suggestions from the community on how you feel we can improve Renderosity.
Subject: Lock entire scene?
drawn ( ) posted Sat, 24 August 2024 at 10:19 AM · edited Sat, 01 February 2025 at 8:50 AM
I've set up a complex scene inside a complex prop, and often when I think it's ready to render, little changes snap into place, throwing it off. somehow I moved the mouse without wanting to. could we have a LOCK SCENE feature that would look the entire scene, without having to tediously lock each part of each figure?
drawn
Rhia474 ( ) posted Sat, 24 August 2024 at 1:35 PM
You can't move anything on a scene without actually clicking on it and moving it while holding mouse or yanking on a body part while holding that button. May it be that you accidentally move the camera? I'd suggest to set up one camera the way you want and then use another one for any changes you want to make.
Also, save button is your friend. Save the way you want right before you hit the render button. Done.
RedPhantom ( ) posted Sun, 25 August 2024 at 8:54 AM
Site Admin
There is also the autosave feature.
Once you save a scene, this will save backups periodically. Then if a scene gets corrupt or crashes, you don't lose everything
mmitchell_houston ( ) posted Fri, 13 September 2024 at 4:19 PM
You're going to have to go into each piece of the prop and lock it manually. I've tried this and it has helped a lot.
System: Lenovo Legion Pro 7 16IRX9H Laptop | Windows 11 Professional | 32GB RAM |  14th Gen Intel® Core™ i9-14900HX | Nvidia RTX 4090 Laptop GPU 16GB 9728 CUDA Cores
mikemitchellonline.blogspot.com   |   Poser Noir Comics Tutorial   |   Illustrations Honored by Renderosity
