Thu, Oct 3, 10:31 AM CDT
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Sep 18 2:50 am)
Subject: Poser 6 'Cant open script for reading' (runPythonScript from CR2)
3dcheapskate ( ) posted Mon, 02 September 2024 at 3:01 AM · edited Thu, 03 October 2024 at 10:25 AM
I've got a simple CR2 that does nothing except call a PoserPython script.
No problems in PP2014
But in Poser 6 I get this
So P6 appears to do the runPythonScript, but can't find the script - is that hat's happening ?
Any ideas why ? (the CR2 and script are in the same runtime)
The 3Dcheapskate* occasionally posts sensible stuff. Usually by accident.
And it usually uses Poser 11, with units set to inches. Except when it's using Poser 6 or PP2014, or when its units are set to PNU.
*also available in ShareCG, DAZ, and HiveWire3D flavours (the DeviantArt and CGBytes flavour have been discontinued).
3dcheapskate ( ) posted Mon, 02 September 2024 at 5:10 AM · edited Mon, 02 September 2024 at 5:10 AM
If I use Windows style path syntax (I'm on Windows 10) it still doesn't work
But with the full absolute path starting "C:\Users\..." it works.
Of course that's no use in a freebie as I have no idea where users will put the file.
So the new question now becomes "can Poser 6 handle runtime relative paths from a runPythonScript statement in a Poser file ?"
3dcheapskate ( ) posted Mon, 02 September 2024 at 5:16 AM
And another related question -
which version of Poser was the first to allow Mac syntax runtime-relative pathnames in the runPythonScript statement in a Poser file ?
jroulin ( ) posted Tue, 03 September 2024 at 10:29 AM
If it is in the same directory I would try this:
runPythonScriptEx "Classics01.py" 0
3dcheapskate ( ) posted Tue, 03 September 2024 at 11:27 AM
Thanks for the suggestion. I'm very rusty on all this - what's the difference between runPythonScript and runPythonScriptEx ?
I've also just identified a nagging thought - didn't Poser 6 require Python scripts to be in the main Poser runtime, not mapped runtimes ?
3dcheapskate ( ) posted Wed, 04 September 2024 at 3:21 AM
My nagging thought was spot on - when I moved my scripts from the desktop runtime I had them in to (backslashes changed to forward slashes simply to post on this forum) C:/Program Files (x86)/e frontier/Poser 6\Runtime/Python/poserScripts/ it worked perfectly, Mac syntax and all.
This is something I clearly knew 12 years ago as it's in the readme of my first freebie with a PoserPython script* - "2 - Copy the contents of the 'Poser Default Runtime' folder from the downloaded zip file to your DEFAULT runtime (These are the PoserPython scripts, which are called from PZ2/PP2 files - if you have several runtimes, then in order for the calls to work it appears that the PoserPython scripts MUST be in the main runtime, i.e. under your Poser installation)."
*South East Asian Duel (Poses, Prop, Scripts) - still avaiable at ShareCG
3dcheapskate ( ) posted Wed, 04 September 2024 at 3:22 AM
So the question now becomes
Which Poser version was the first to support calling of PoserPython files in mapped runtimes from runPythonScript ?
