Wed, Nov 20, 9:26 AM CST
Renderosity Forums / Freestuff
Welcome to the Freestuff Forum
Forum Moderators: wheatpenny, RedPhantom Forum Coordinators: Anim8dtoon
Freestuff F.A.Q (Last Updated: 2024 Nov 17 8:21 pm)
Welcome to the Freestuff Forum. The Freestuff Forum is intended for all  freestuff related postings within our community. This is a highlight area where our membership is invited to review, announce and give feedback in greater detail on various freestuff items offered.  Members can also post wishes of freestuff items they would like to see.
Notice: Links to offsite 'For Sale' items will be removed
Renderosity Free Stuff Area
Free Stuff Gallery
Free Stuff Guidelines
Subject: Multi-figure bookstacks for Poser
3dcheapskate ( ) posted Mon, 09 September 2024 at 7:11 AM · edited Wed, 20 November 2024 at 9:23 AM
This is the supporting topic for my "Multi-figure bookstacks for Poser" freebie in the Renderosity Free Stuff.
Details will be added in the next post once the freestuff upload has been approved.
(Note: This topic needs to be in place before I actually upload the freestuff item so that I can link to this topic from the freestuff item)
The 3Dcheapskate* occasionally posts sensible stuff. Usually by accident.
And it usually uses Poser 11, with units set to inches. Except when it's using Poser 6 or PP2014, or when its units are set to PNU.
*also available in ShareCG, DAZ, and HiveWire3D flavours (the DeviantArt and CGBytes flavour have been discontinued).
3dcheapskate ( ) posted Mon, 09 September 2024 at 11:03 AM
The freebie's been approved, so here's the link to it in the Renderosity Free Stuff - Multi-figure bookstacks for Poser (renderosity.com)
Please feel free to post here any comments (good or bad - constructive criticism preferred), suggestions for improvement, and/or questions about this freebie.
3dcheapskate ( ) posted Mon, 09 September 2024 at 11:07 AM
Basically a Poser figure containing four stacked books, each of which can be independently swapped, morphed and adjusted (within limits).
Figures can be stacked one on top of another to create larger stacks.
Stacks of 4, 8, 12, ... 60, 64 books are included, along with a 128 and a 256 book stack .
Since manually adjusting each book in a large stack is impractical there are PoserPython helper scripts to randomize, reset, and change textures. These scripts can be accessed directly from proxy CR2s alongside the stacks.
*** WARNING: DON'T USE POSER'S BUILT-IN 'DELETE FIGURE' WITH THE 'DELETE ATTACHED' OPTION CHECKED FOR STACKS LARGER THAN 40 BOOKS AS THE DELETION TIME IS HUGE AND POSER WILL EFFECTIVELY LOCK UP FOR HOURS. USE THE INCLUDED 'DELETE LINKED' SCRIPT WHICH ONLY TAKES A FEW SECONDS EVEN FOR HUGE STACKS ***
Created in Poser Pro 2014. Tested on a Windows 10 PC in Poser 6 and Poser Pro 2014.
3dcheapskate ( ) posted Mon, 09 September 2024 at 11:12 AM
If anybody's interested in how this came into being then posts #54 to #135 of "My rather infrequent, and possibly apocryphal, 'books project'." topic on HiveWire3D has all the ins and outs.
3dcheapskate ( ) posted Tue, 10 September 2024 at 10:40 AM
FIGURE STRUCTURE / HIERARCHY
The BookStack4 figure has six bones/bodyparts in a chain:
Body > Stack > Book1 > Book2 > Book3 > Book4 > TopOfStack
The first bone/bodypart (Stack) and last (TopOfStack) have no associated geometry and all their parameters are fixed (force limits is set and the minimum/maximum limits are the same) and the dials are hidden. The reason for the 'Stack' bone is explained in post #67 of the HiveWire3D topic (basically the joint parameters are different for the first bone and I couldn't do what I needed) and the reason for the TopOfStack bone in post #66 of the HiveWire3D topic (basically ensures that a nested child stack will respond correctly when the thickness of the top book changes).
The remaining four bones are for the four books. Here's the hierarchy for a single figure:
and four a stack of two figiures, the second being parented to the TopOfStack bone of the first.
3dcheapskate ( ) posted Tue, 10 September 2024 at 10:44 AM · edited Tue, 10 September 2024 at 10:45 AM
A COUPLE OF SEUSSIAN 256 BOOK STACKS, JUST BECAUSE...
I love scrolling this picture, but I think it needs some birds, mountain goats, etc...
3dcheapskate ( ) posted Tue, 10 September 2024 at 11:10 AM · edited Tue, 10 September 2024 at 11:10 AM
The following renders give a hint at the flexibility of this approach, a few examples of what you can do by simply loading a bookstack, in this case tthe Stack08 (2figs).cr2 figure and then running the reset and/or randomize and/or material helper scripts.
The (non-interactive) reset script makes it into a very tidy stack of curved hardbacks (the odd shadow here is, I think, due to the books being very small and not using ray-tracing for shadows)...
then just run the (non-interactive) randomize script  to get a jumbled stack....
Next run a material helper script to change to the classics and the interactive randomize script to select full 360 degree rotations....
...and the interacive randomize again to select only hardback geometries, twist and shear morphs, and small rotations...
...and again, but selecting just paperbacks, all morphs, position and size, and very small rotations - and run the material helper script for Pulp02
3dcheapskate ( ) posted Tue, 01 October 2024 at 2:30 AM
Just about to upload an update version, release 2
hborre ( ) posted Tue, 01 October 2024 at 8:55 AM
Online Now!
Cool!  Thanks.
3dcheapskate ( ) posted Tue, 01 October 2024 at 5:50 PM
3dcheapskate ( ) posted Tue, 01 October 2024 at 6:00 PM
If anybody's interested, and also for my own cross-reference, the additional work that went into creating this is documented in posts #146 to #177 on the HiveWire3D topic
