Sat, Feb 1, 1:41 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 31 9:45 am)
Subject: Import into Poser from Daz
Warschau001 ( ) posted Sat, 05 October 2024 at 5:47 AM · edited Sat, 01 February 2025 at 12:49 AM
When import Daz ( DUF ) file into Poser it is imported. But  it load but no shown when click on it on Poser . Scale is shown 0.  Where could be the problem pls ?
RedPhantom ( ) posted Sat, 05 October 2024 at 7:50 AM
Site Admin
While I doubt it will help, did you try increasing the scale to 100? That's the normal scale setting.
How are you importing a Duf file? That isn't one of the given options.
hborre ( ) posted Sat, 05 October 2024 at 8:08 AM
Poser does not recognize nor can it open DUF.  You must convert the content file into another format that can be imported into Poser.  Unfortunately, many of the older export and import options are no longer conveniently available, and some of the current methods are hit-or-miss depending on how much time you want to invest in creating quality items for export into Poser.
Warschau001 ( ) posted Sat, 05 October 2024 at 9:34 AM
Thx for answers. I tried to increase scale. It not helped. I use dson importer. Some files seem to be can importet without problems to pser and other it no worked. ( as it is imported but not be shown when click on icon ) . What would be alternative to dson importer.pls ? as it would be win 11 and poser 11. BTW could it be win 11 be the problem as on win 10 it seem to work all fine.
Warschau001 ( ) posted Sat, 05 October 2024 at 9:59 AM
Tx. but i ve poser 11 and is written minimum poser 12 is needed.
hborre ( ) posted Sat, 05 October 2024 at 10:46 AM
DSON Importer needs Poser Companion Files to convert items from DAZ to Poser.  Otherwise, attempts to use the script will fail.  There is a feature in DAZ that allows the creation of PCFs for those files that don't have them already.  If you are familiar with these files, then you should already know how to install, use, and convert your content.
Warschau001 ( ) posted Sat, 05 October 2024 at 11:00 AM
Thx  again. n daz the files open more or less good. but in poser . after imported from daz with dson  importer  some not all not open after click on it. Sadly dson importer no londer seem to be supported.
hborre ( ) posted Sat, 05 October 2024 at 11:25 AM
DSON Importer has not been supported for quite some time.  Give an example which DAZ product you are having problems with.
Warschau001 ( ) posted Sat, 05 October 2024 at 11:52 AM · edited Sat, 05 October 2024 at 11:59 AM
My poser look like this
image poser
hborre ( ) posted Sat, 05 October 2024 at 1:44 PM
Based on the information on the Daz webpage, it appears that a Poser Companion File (PCF) is not available for this product. Have you generated a PCF in DAZ Studio for Poser? This process is essential to produce the CR2 export file required for the DSON Importer application.
Warschau001 ( ) posted Sat, 05 October 2024 at 1:55 PM
Sorry. I googled but what is a PCF File ? Usually i export daz files with DSON to poser .
Warschau001 ( ) posted Sat, 05 October 2024 at 2:09 PM
This is how poser directory look like after DSON import
 poser directory
hborre ( ) posted Sat, 05 October 2024 at 3:27 PM
A Poser Companion File (PCF) contains the necessary files for Poser to accurately load exported content, which is subsequently placed in a specific runtime folder within your Poser Library. Should DAZ not provide PCFs, you must generate them yourself. Begin by opening DAZ Studio and loading the item intended for export to Poser. The illustration that follows will indicate the feature's location and the related panel.
You may need to experiment with the settings.  This is the alternate method to creating the Poser files for the DSON Importer.  It works well for props and Genesis/Genesis2/Genesis3 content figures.
Warschau001 ( ) posted Sat, 05 October 2024 at 7:31 PM
thx you again. I usually do this that way you tell me. With content  - panel and create file. The result is the - my poser . And not open able :(
hborre ( ) posted Sat, 05 October 2024 at 8:40 PM
Have you converted the outfit's general weight rigging to TriAx Weight and saved it as a new scene subset in a temporary folder? This step could be the reason it's not converting to Poser. It's a similar procedure to the one used for converting Genesis 3 Male/Female figure assets for PCF conversion. Please confirm whether you have completed or overlooked this process.
Warschau001 ( ) posted Sun, 06 October 2024 at 11:30 AM
Thx you for support. As somehow it still no work. I receive python error. And still scale 0.
