Sat, Jan 4, 11:14 PM CST
Renderosity Forums / Poser 13
Welcome to the Poser 13 Forum
(Last Updated: 2025 Jan 03 9:11 am)
Subject: Depth of field is permanent...
blackbonner ( ) posted Tue, 08 October 2024 at 10:05 AM · edited Thu, 02 January 2025 at 5:50 PM
Hello fellow Poser User,
I'm working on a scene right now with two figures involved.
Just to see if it works for that scene, I switched Depth of Field on, did a few test renders but it doesn't came out as I thought it would.
Long story short, I switched DoF off in the render settings, rendered the shot again and it seems, the DoF is still active despite the fact that I switched it off.
I'm running the latest version of Poser 13.3.824.
My Nvidia GPU driver is fresh installed.
Is anyone made a similar observation?
Does anyone have an idea what's the cause of this, other then a corruped pz3 file?
hborre ( ) posted Tue, 08 October 2024 at 11:29 AM
Try assembling simple scenes and compile a series of renders.  If you get similar results, fill out a support ticket.  It may be a bug.
Also, DoF is dependent on aperture values (f-Stop) and distance.  The larger the f-Stop value, the sharper the image will be within a distance range.  The lower the f-Stop value, the shallower the sharpness within a distance range.  You will need to consider this when rendering a portrait or landscape.  You will need to increase the pixel sampling to refine the final render, too low and the background will appear too grainy.
nerd ( ) posted Tue, 08 October 2024 at 2:51 PM
Forum Moderator
No need to open a support ticket. I'll add a bug to the tracker. This is really easy to reproduce.
blackbonner ( ) posted Wed, 09 October 2024 at 2:49 AM
Ups, seems I stumbled on something.
I stay tuned for news.
blackbonner ( ) posted Thu, 10 October 2024 at 3:28 AM
I just wanted to add another observation regarding the DoF function.
In the aftermath of my initial posting, I went to check if I could render the scene with another camera without the DoF effect.
Turns out the DoF is turned on in every camera available.
Since the DoF checkbox in the render settings panel is unchecked in any case, DoF can't be turned off for this particular file.
I didn't checked if a new scene is also set to use DoF. If that's the case I will come back and put in another post.
blackbonner ( ) posted Thu, 10 October 2024 at 9:09 AM
Addition to the previous post:
I created a new scene and rendered it, everything was fine.
I switched DoF on, took a render and DoF worked as expected.
I switched DoF off and took a render with face, dolly, aux, hand and posing camera...DoF was always active.
I created a new camera, rendered the shot and...still DoF is on.
The moment you switch DoF on, the scene can't be rendered without DoF anymore.
I also tryed to get rid of it by hitting the undo button to the point the scene was empty.
It doesn't work.
VedaDalsette ( ) posted Thu, 10 October 2024 at 2:04 PM
Happened to me, too. I unclicked the Use Cache in the Render Settings and the problem went away.
Old lady hobbyist.
All visual art or fiction is "playing with dolls."
Versum ( ) posted Thu, 10 October 2024 at 2:11 PM · edited Thu, 10 October 2024 at 2:12 PM
ways to fix the issue with the DOF that does not turn off
1 swap render from GPU to CPU and back
2 Restore defaults
3 best choice - Turn off cache this will solve the issue and the on off will work again
blackbonner ( ) posted Fri, 11 October 2024 at 5:36 AM
Thanks for sharing those advice to adresse this problem.
I checked it out and...it works pretty fine, of course.
At least we have a workaround until the next update, I guess.
blackbonner ( ) posted Mon, 14 October 2024 at 4:48 AM
Amendment:
I tested the DoF settings on Firefly as well, you can switch it on or of to your liking. Works as usual.
