Thu, Jan 30, 6:09 PM CST
Renderosity Forums / New Poser Users Help
Welcome to the New Poser Users Help Forum
New Poser Users Help F.A.Q (Last Updated: 2025 Jan 30 10:47 am)
Subject: Poser Andy
Atalantia ( ) posted Wed, 23 October 2024 at 8:09 AM · edited Thu, 30 January 2025 at 12:50 PM
I have a problem with the default character Andy. The one that appears when you start Poser the first time. The bones don't stick together when I use the Translate/Pull tool.
In fact it's it little bit more behind it. When I grab his arm the first time, it works. I can lift his arm. When I release and grab the arm again to pull it to left or right, the arm separates from the shoulder. When I grab his hip and pull up or down the skeleton sticks together how it should.
Someone an idea what's wrong?
hborre ( ) posted Wed, 23 October 2024 at 9:04 AM
I don't see anything wrong with posing Andy using the Translate/Pull tool.  Breakage could occur if you go beyond the capacity settings of the joints, but I can't duplicate that in my Poser version.  The hip on any figure acts as the center of its universe; it will translate the entire figure in any direction.  If your intention is to pose the hip while other body parts respond to its movement, then you need to turn on Inverse Kinetics for the legs and hands.
You will benefit in using the translation tools, Direct Manipulation tool, and Parameter Dials to achieve a final pose.
Atalantia ( ) posted Wed, 23 October 2024 at 10:13 AM · edited Wed, 23 October 2024 at 10:15 AM
Thank you for care. Please look at the video. Maybe you can spot what I'm doing wrong.
https://youtu.be/0ehOQ-m8Wi8
hborre ( ) posted Wed, 23 October 2024 at 11:49 AM
I see what you mean.  Andy seems to behave himself in Poser 13.  Let me see how he behaves in P11.
hborre ( ) posted Wed, 23 October 2024 at 12:00 PM
I have manipulated and abused Andy in Poser 11 and have not broken him the way you demonstrated.  I did notice that you are running a MAC Poser version.  I suggest you submit a support ticket and allow the techs to look closely at what is happening.  Although Poser 11 is no longer updated, they may be interested to see if this is also happening in P13.
nerd ( ) posted Wed, 23 October 2024 at 4:59 PM · edited Wed, 23 October 2024 at 4:59 PM
Forum Moderator
Andy is not made with linear joint zones. I never expected him to actually be used that way. Yes, I originally rigged him. So if you really want to play Stretch Armstrong with him do this ...
Select the body part you want to be stretchy
Open the Joint Editor [Ctrl]+[Shift]+J
Click on [Create Smooth Trans] then [OK]
Andy says, "I am Gumby!"
Rinse and repeat for any joints you wish to stretch.
Atalantia ( ) posted Wed, 23 October 2024 at 10:37 PM
Also stretching out the limbs is not something I want.
But have a look again to this video. I deleted the preference file and the application support folder, cache files and general all the peripheral Poser files. Of course not the content folder at User/shared.  It shows that after starting Poser translate works after undo it doesn't work anymore. Please have a look at the video:
https://youtu.be/_Sw_7Ptax28
