(Last Updated: 2025 Jan 31 3:19 pm)
are you getting any errors in your message log?
Duh! I didn't even think to look there. Thanks.
Just ran it again. Here's the error log. It's like it simply doesn't want to render this prop!
Old lady hobbyist.
All visual art or fiction is "playing with dolls."
It looks like Hither to me. It's like everything closer than a plane perpendicular to the camera is getting cut off, and everything further than that is being rendered. The only odd thing is that the preview should reflect that setting too. (But maybe it doesn't correspond properly if the camera's scale isn't 100%?)
Thank you, ChromeStar, hborre, and RedPhantom. It was definitely the hither. I know to increase the yon when I can't see my distant background, but I've never touched the hither before. Seems the Main Camera default hither is set to .8. Powerage used this camera for the prop's camera shots. The one I selected to show you had the hither set to 64. I lowered the hither and got the shot! Thanks for the hither lesson!!! Now, I'll just update all those camera shots.
Old lady hobbyist.
I don't think I've ever had this problem before. I purchased Powerage's The Factory and Superfly-rendered some of the included camera shots. It seems on every shot I'm unable to render the whole image. It displays fine in preview.
Here's a Preview preset rendered image.
Here's an Optix Medium preset rendered image.
Here's a GPU Fast preset rendered image.
It doesn't seem to matter if I click or unclick Progressive Refinement or Use Cache. Here are the preset settings for the 3 renders.
I get the same results with a CPU Fast preset render.
Here are my render preferences.
It's a large prop (525973 polys, 493495 verts), but I've rendered props this large before. Do I not have enough graphics power in my computer to handle it?
I can't find anything in the prop that's not Visible in Camera. Materials look okay. I clear the cache before I load it. Any idea what might be wrong? (I realize I can break it up into sections, but I'd rather not if I don't have to.) Thanks.
Old lady hobbyist.
